Basslake Adventures Trail Video
Results 1 to 6 of 6
    Amorosa
    Thanked: 346
    Default Basslake Adventures Trail Video
    Did Basslake Adventures last weekend. See the video below. Hope it provides an overview of what to expect from the trail.
    https://youtu.be/lTPu6nvj0s8
    Bush Lapa Miskruier 586
  2. The Following User Says Thank You to Bogaards For This Useful Post:
    Amorosa
    Thanked: 346
    Default Re: Basslake Adventures Trail Video
    Just a note on trail. I found the map the provided a bit confusing, especially if you try to find the numbers on the track since some of them were missing. Also difficult as the map is over a couple of pages.
    Note that the track is a bit overgrown, so you will definitely pick up some light Scratches.
    Vanderbijlpark
    Thanked: 668
    Quote Originally Posted by Bogaards View Post
    The layout of the track, as well as the map is a bit misleading. Took me about 3 visits there to really know the place.
    Bass Lake in the wet is the best.
    Amorosa
    Thanked: 346
    Quote Originally Posted by clubbie View Post
    I agree on layout, if I go again I would rather go in a group or with someone who has been there before. Only problem with the group is that you will hold people back when moving cameras etc around...
    Vanderbijlpark
    Thanked: 668
    Its a fun track though.
    Amorosa
    Thanked: 346
    It is, they can maybe just trim some of the bushes, can imagine that you will pick up a lot of scratches with a wider vehicle.
