2 year solo 4x4 africa exploration - Page 9
Page 9 of 9 FirstFirst 1 2 3 4 5 6 7 8 9
Results 161 to 173 of 173
  1. #161
    Jun 2012
    Pretoria East
    Thanked: 255
    Default Re: 2 year solo 4x4 africa exploration
    Quote Originally Posted by smcs View Post
    Like your suggestion. Unfortunately, more weight on top - but everything is a compromise!
    See earlier response. 1.5 kg is not a major issue over the cab. You have a front sway bar for stability up front. If you must and remain concerned about cornering stability, fit a rear (upgraded) sway bar to the rear axle. There are factory mounts for one.
  2. The Following User Says Thank You to locklaw For This Useful Post:
  3. #162
    Sean McSweeney, Johannesburg
    Thanked: 70
    I'm thinking of leaving everything as it is and mounting the Hi-Lift Jack to the front of the roof carrier. Maybe also, spade on the side of the roof carrier. Your thoughts, please.
    2008 Nissan Navara 2.5 dCi D/C 4x4
    Triple battery system (2 x 120Ah secondary batteries), Armadillo, Frontrunner drawer system, Outback roof rack over loadbay, Reserve fuel tank (50l), Inboard water tanks (80l), Bridgestone Dueler A/T tyres, OME suspension, ARB bar, T-Max PEW-9000 winch, Front Runner Rear wheel carrier, Safari snorkel, IPF spots, Dust-proof kit, For Fours Bashplate.
  4. #163
    Feb 2017
    Santa Cruz, CA
    Thanked: 181
    We have a 79 d/c. Our spade is mounted on the side of the roof rack w/ the Front Runner spade mounting bracket. Negatives, no locking mechanism, positives, easy access and when it gets dirty it's out of the car.
    We keep our hi-lift mounting jack behind the rear seats in a canvas bag (it came with one). This doesn't rattle and keeps the weight low down and centered vs. high on a rack or to far back on the tyre carrier. I've also seen mounted to the bull bar, which appeals to me to keep some weight forward, though not good in an accident! Behind the seats may already be utilized for something else for you, but for us it works great. Negatives, not easy access, but we solve this by not getting stuck (ha! Famous last words...). We just used the bottle jack to change a tyre for punctures.
  5. #164
    Jun 2012
    Pretoria East
    Thanked: 255
    The front and rear sections of the rack are unsupported and the mount will crack on the first bad road. The front and rear slats of the racks are light duty. See the Front Runner website in this regard.
    With "luck" the jack will hit the windscreen when you remove it in a stress situation.
  6. The Following User Says Thank You to locklaw For This Useful Post:
  7. #165
    Feb 2007
    Thanked: 80
    Quote Originally Posted by CalDriver View Post
    I trust the high lift jack will be properly secured as it can become a dangerous missile in an accident.
  8. #166
    Thanked: 70
    Open circuit test of my 325W Canadian Solar panel (mounted flat on top of RTT). I am not entirely sure what this is telling me. Any comments?
  9. #167
    Ruimsig
    Thanked: 2298
    Interesting data. Firstly, sun tracking seems to be recorded assuming the panel isnt being moved hence the low values early morning and towards the evening.
    The efficiency values are also interesting. The max value is in the upper 80s. Is the panel still mounted flat when this was recorded and is the vehicle sitting near any sun blocking structures?
    If there is no obstruction and the panel is clean and functioning properly and was moved and angled to track the sun, then there could be an issue with the panel although (not knowledgeable in this field) it is possible that achieving 100% is not to be expected?
    2010 Hummer H3 5.3lt V8, 300 HP, FDL, RDL, CDL, TC and 4:1 Low Range
    Discovery and Range Rovers: SOLD: enough is enough
  10. #168
    Thanked: 70
    No obstacles, no sun tracking, panel lying flat same position all day.
    100% efficiency would "probably" only be possible in ideal lab situations.
  11. #169
    Aug 2016
    Thanked: 100
    Very very roughly.
    It looks pretty good.
    Total Watt / 12 V =149 Ah
    One freezer running flat out during this period could use 7.4 A x 10 hours = 74 Ah.
    That leaves 149 - 74 = 75 Ah for battery charging.
    Say carging efficiency is 80%
    That gives your batteries a gain of 60Ah
    If you are in severe circumstances the freezer can run at average 5 A overnight for 14 hours = 70 Ah
    You are then still losing 10 Ah per day
    If you drive during the day for 2 hours the freezer runs off the alternator for 2 hours and the alternator charges the battery for 2 hours
    You will easily make up the deficit.
    If the circumstances are not as severe you should not run into a defecit.
    Note the required battery capacity in the severe conditions.
    If you use a lead acid 100Ah you can run it down to 50% and can charge it only to about 90% in the time given with an unlimited supply.
    The max useable Ah will be 40Ah
    The 60Ah required tells you to install 2 batteries.
    As jou can see it is pretty simplified calculating, but it must be practical and always plan on the worst circumstances.
    Hope that helps ?
  12. The Following 3 Users Say Thank You to Pieter de Waal For This Useful Post:
  13. #170
    Thanked: 70
    Quote Originally Posted by Pieter de Waal View Post
    Very very roughly.
    Hope that helps ?
    Thanks for your very helpful (and practical) explanation, Pieter. Accepted that there are many variables and that this is a rough estimate.
    - Batteries: 2 x Blue Nova 108Ah LiFePo.
    - DC/DC Charger: Redarc BC/DC (50A).
    - AC/DC Charger: Victron Blue Smart (Bluetooth) 30A
    - Solar Controller: Victron Smart Solar MPPT 100/20
    - Battery Monitor: Victron BMV-712 Smart
    - Inverter: Victron Phoenix VE Direct 12/1200 with remote
  14. #171
    Thanked: 70
    Does it take 2 years to prepare a vehicle for a 2 year overland trip of Africa? Possibly it does.
    It has taken me 5 months so far - and I am almost done with the major vehicle preparation. There will of course always be small niggles that have to be sorted out later.
    Overall, I am very happy with the progress made.
    I am generally very happy with the suppliers and fitters used. To a large degree this is thanks to previous experience and a great deal of research.
    Here is the vehicle ready to be packed.
    Once again, my thanks to all those on the forum who have provided input and advice.
ID:	539942Click image for larger version.
ID:	539943Click image for larger version.
ID:	539944Click image for larger version.
ID:	539945Click image for larger version.
ID:	539946Click image for larger version.
  15. The Following 3 Users Say Thank You to smcs For This Useful Post:
  16. #172
    May 2017
    Thanked: 599
    Super cool. Well done !
    Fiddler
  17. The Following User Says Thank You to EHoffmann For This Useful Post:
  18. #173
    Helderkruin
    Thanked: 361
    Mooi en goeie keuse 4x4 vir jou toer
