My Ultrasonic Cleaner
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 53
    Gaborone, Botswana
    Thanked: 1201
    Default My Ultrasonic Cleaner
    On 13 December I ordered a Driver Board and 2 x 50W 40kHz transducers from Banggood.
    This : https://www.banggood.com/AC-220V-Ult...r_warehouse=CN
    Kobus
  2. The Following User Says Thank You to KobusDJ For This Useful Post:
    Gaborone, Botswana
    Thanked: 1201
    Default Re: My Ultrasonic Cleaner
    Collected the package on 18 January from Botswana Post. Had to pay BWP8-00 for the local duties.
    This is what I got.
    Kobus
    Gaborone, Botswana
    Thanked: 1201
    First order of business.... fix the transducers to the s/steel bucket.
    Now wait for tomorrow for the epoxy to cure properly.
ID:	516648   Click image for larger version.
    Kobus
    Gaborone, Botswana
    Thanked: 1201
    And there was evening, and there was morning.
    Some more parts.
    12V DC fan. (Only one needed). 12V Power Supply. On/Off Switch. Plastic Addis bucket.
    Cutting some holes
    It is coming togither.
ID:	516650   Click image for larger version.
ID:	516651   Click image for larger version.
    Kobus
    Gaborone, Botswana
    Thanked: 1201
    Everything mounted and glued together.
    Lid on and turned right side up.
    The other side.
ID:	516653   Click image for larger version.
ID:	516654   Click image for larger version.
    Kobus
    Gaborone, Botswana
    Thanked: 1201
    In action.
    Kobus
  8. The Following 2 Users Say Thank You to KobusDJ For This Useful Post:
    Sep 2011
    Potch/Brits
    Thanked: 583
    I like it!
    What parts will you be cleaning with it?
    Aug 2017
    Durban or Centurion
    Thanked: 1268
    I like it. US cleaners are ridiculously expensive in ZA.
    What is the volume of your container? How effective is it?
    Nigel
    Thanked: 2311
    ............. How effective is it?
    Knowing Kobus, extremely.
    Uniglide
    +27 zero eight 2 four 95 9252
  12. The Following User Says Thank You to Henris For This Useful Post:
  13. #10
    Gaborone, Botswana
    Thanked: 1201
    Thanks for the thumbs up.
    I filled it with +- 4L water with a bit of dish-washing soap (Sunlight).
    First test was my watch. (Only the s/steel arm band! ) The stuff that came out between the links was unbelievable.
    Played some more with wife's jewelry. It seems functional.
    I need to play some more with the cleaning solution. The Internet recommends a little bit of ammonia with the dish-washing liquid into the water.
    Kobus
  14. #11
    Gaborone, Botswana
    Thanked: 1201
    Cost:
    US$37.99 + US$4.47 via Air Parcel Register from Banggood. It took 5 weeks to Botswana Postoffice.
    BWP 8.00 for customs.
    BWP 89.95 for the Addis plastic bucket.
    The other stuff I had laying around.
    Kobus
  15. #12
    Hillcrest, Malaysia
    Thanked: 6516
    Engine cleaner, then rinse in water ?
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  16. #13
    Gaborone, Botswana
    Thanked: 1201
    @Fluffy. Engine cleaner should work for greasy parts.
    For my own good, I will use softer solutions for the household stuff
    Kobus
  17. #14
    Aug 2010
    Amanzimtoti/Johannesburg
    How about the cleaning solutions sold by the gun companies? I use some of these regularly and it is most effective.
    Toyota Land Cruiser 79 4.2D SC
    Toyota Hilux 2.4 GD6 DC
    ZS5RJ
  18. #15
    durban
    Thanked: 1119
    What are the two cylinder disc thingies and how does it work? Time frame?
  19. #16
    Gaborone, Botswana
    Thanked: 1201
    Are you asking about this?
    It is the ultrasonic transducer. Attached to the s/steel bowl it is causing the oscillation in the water at high frequency. 40kHz in this case.
    I'm not sure what you want to know about Time Frame.
    Kobus
  20. #17
    durban
    Thanked: 1119
    Is it a hour long process? I wonder if Botswanas postal system is better than here. That was quite quick ,five weeks.
  21. #18
    Gaborone, Botswana
    Thanked: 1201
    Is it a hour long process?......
    No, a few seconds up to a few minutes, depending on the dirt. I won't run it for more than 2 or 3 minutes at a time.
    Kobus
  22. #19
    Jan 2015
    Vredenburg
    Thanked: 943
    In action.
    Daai ding is wild!
  23. The Following User Says Thank You to Karoo Klong For This Useful Post:
  24. #20
    Gaborone, Botswana
    Thanked: 1201
    Quote Originally Posted by Karoo Klong View Post
    Daai ding is wild!
    Ek hou van 'n wilde ding.
    Kobus
  25. The Following User Says Thank You to KobusDJ For This Useful Post:
