Ford Ranger 3.2 Cat removal and ECU Remap by Force Maps (Bullit Oosthuizen)
Results 1 to 7 of 7
    Nov 2012
    Default Ford Ranger 3.2 Cat removal and ECU Remap by Force Maps (Bullit Oosthuizen)
    I intended to only remove the CAT but after seeing what Bullit can do, I decided to go for the re-map, this is a Performance/Economy map so nothing too hectic.
    I must say, Bullit knows his stuff and did a great job. My Ranger now goes like a bullet, I should have removed the CAT earlier, it was blocked quite a bit and surely hampered the Turbo's performance.
    Search for Force Maps on facebook.
    See attached Dyno Chart
    159 kW
    517 Nm
    Current: Ford RANGER 3.2 XLT HR 6MT 4x2 DC
    Mokopane/Potch
    Default Re: Ford Ranger 3.2 Cat removal and ECU Remap by Force Maps (Bullit Oosthuizen)
    Bullit is a really good tuner, he first mapped my v9x last year with towing heavy loads in mind. Even a 3ton trailer combo could not get the EGT's above 690'C. Then I after I upgraded my turbo he changed the mapping for the new turbo and well same thing happend. More power for less fuel and EGT's stay the same not once going over 690.
    My v9x has done 35k km since then.
    Nissan Navara v9x - For towing
    Ford Fiesta 1.0 Ecoboost - For the wife.
    80 Series cruiser - To use the fuel I save on the other two.
    Hilux - Work mobile
    Heimrich Swart
    Brilliant products are ruined by incompetent suppliers.
    Jun 2016
    Secunda
    Quote Originally Posted by Swartjan View Post
    Hi Swartjan, what turbo upgrade did you do on your V9X?
    2013 Nissan Navara 3.0 DCi 4x4 D/C - Rooigevaar
    2015 Nissan Hardbody NP300 2.4 4x4 D/C - Kragtige Pakdonkie
    2012 VW Amarok 2.0TSI D/C 4x2 - SOLD (Needed a 4x4)
    2010 VW CC 2.0TSI DSG - SOLD
    2008 VW Golf 5 2.0 Trendline - SOLD
    Mokopane/Potch
    New compressor wheel that the blade geometry, angle and size was increased. Then they exhaust wheel and vanes was replaced with the one's from the bmw 3.0lt diesel.
    With this turbo you cannot run the standard size exhaust and intercooler but those I upgraded long ago.
    After the first tune it was to powerfull for the gearbox so bullit turned down the boost a bit and now it's happy. The gearboxes on the v9x are rated for 700nm.
    Hilux - Work mobile
    Heimrich Swart
    Garsfontein, PT of A
    Quote Originally Posted by FordFanatic View Post
    159 kW
    517 Nm
    Hi,
    So after a couple of months, everything still running good?
    I have a 3.2 Manual with 30 000km on and was considering a remap.
    How does this effect warranty?
    Just want a little extra oompf and some better fuel consumption.
    Just your thoughts?
    Get Psyched!
    Jul 2017
    You will loose your warranty.
    Removing a CAT, remapping ecu, messing with turbo etc. All will void the warranty.
    2008 Ford Ranger 3.0 XLT 4x4
    Mar 2007
    Irene
    Quote Originally Posted by Smart Bar View Post
    Hi,
    Just your thoughts?
    Extra oomph and better fuel consumption are exact opposites! Mother Nature (physics) gives nothing for free, the amount of fuel you burn is more or less equal to the amount of energy (oomph if you like) you get....
    And yes, you tinker like that you also kiss your warranty good buy....
