Small circlip for Drone motor
Results 1 to 10 of 10
    Thanked: 48
    Default Small circlip for Drone motor
    Ons het vir my seun 'n klein baie entry level drone gegee vir kersfees..... Sky-Viper Fury
    (ons wou eers kyk of dit net 'n craze is en of hy regtig groter wil gaan later)
    Hy het die drone in garage gevlieg om te begin en heel lekker reggekom. Een crash was bietjie rof en die bitter klein circlip wat die shaft van die rotor vashou het afgespring en is GONE!
    Ek het nou al paar hoby shops in omgewing gebel en niemand kan my help nie.
    Die part wet ek soek is 'n e-type circlip vir 1.7mm shaft
    Waar kan ek probeer om hievan te koop?
    Coenraad Basson
    Hilux D/C 3.0 D4D
    Prado 4.0 V6 Auto VX
    Sep 2014
    Little Falls
    Thanked: 100
    Default Re: Small circlip for Drone motor
    Hi there Coenraad
    I'll have a look at home tonight if I might have one for you.
    Is the shaft OD 1.7mm, or the notched section the E-clip sits in?
    Kind regards
    Justin
    2002 Defender 300Tdi PU wiff a hardtop - They call him Murphy
    2016 A45 AMG - Rapid
    2013 Tiger XC800 - Tear it up
    2016 Thruxton R - Sublime
    2004 Buell 12R - Mechanical Music
  3. The Following User Says Thank You to MudMuppet For This Useful Post:
    Thanked: 48
    Quote Originally Posted by MudMuppet View Post
    Hi there Coenraad
    Kind regards
    Justin
    Thank you!!
    Shaft OD 1.7mm
    Notch OD 1.2mm
    Coenraad Basson
    Hilux D/C 3.0 D4D
    Sep 2014
    Little Falls
    Thanked: 100
    Thanks Coenraad.
    I'll check and let you know either later or in the morning.
    May 2016
    Thanked: 2620
    These places should have something to fit:
    • Decent spares shop
    • Engineering supplies
    • "Nut and Bolt" shop
    take the drone with to have them fit.
    2006 VW Touareg V10 TDi
    Thanked: 48
    I have heard "Engineering Supplies Store" a couple of time but no-one can point me to one in Stellenbosch region.
    We had a "Nut and Bolt Shop" but they closed down last year...
    Coenraad Basson
    Hilux D/C 3.0 D4D
    May 2016
    Thanked: 2620
    Quote Originally Posted by CoenraadB View Post
    You could even try the co-ops in the region.
    Sep 2014
    Little Falls
    Thanked: 100
    Morning Coenraad
    Unfortunately the few I have are bigger than what you need
    I am measuring mine at just over 2mm meneer.
    Kind regards
    Justin
    Sep 2014
    Little Falls
    Thanked: 100
    What about Apple Hardware in Strand Coenraad?
    Mar 2007
    Thanked: 627
    Het jy al n magneet gebruik om hom in die motorhuis te soek ?
    2011 Daihatsu Terios 4x4
