Disco 4 + Roof top tent + key in tent = flat battery... Help?
Results 1 to 13 of 13
    Mar 2012
    Fourways
    Thanked: 434
    Default Disco 4 + Roof top tent + key in tent = flat battery... Help?
    Question for those those who camp with the D3/ D4/ RR? that have the proximity feature on that unlocks the car on handle pull when you are near the car.
    When I sleep in my roof top tent, the key is in the tent with me but it seems to be within the unlock proximity so anyone can open the doors and even worse, this seems to run the battery low overnight if not flat when camping 2 days in a row.
    Any tips on what to do with the key to prevent this?
    Rob,
    D4 SDV6 HSE ARB Bullbar, Compos, BFG 265/65R18s, Big Country drawers, National Luna 52L, Dometic 50L, Spare Wheel Carrier, Roof Rack, Hardshell RTT, FR 50" LED Bar, Lift Rods, Mantec Snorkel, C-TEK Dual batt system, 270 Ostrichwing, Maxtrax, TXG Rock Sliders, IIDtool, shelf
    Forest Hills, KZN
    Thanked: 803
    Default Re: Disco 4 + Roof top tent + key in tent = flat battery... Help?
    Quote Originally Posted by DETOUR-GP View Post
    Remove the battery?
    2003 LR Discovery 2 Td5 ES - mods list to be updated [Husky]
    Stellenryk, Bellville
    Thanked: 290
    Can you not temporary disable this feature when camping?
    Dual battery system
    57 mm freeflow system
    General Grabber AT3's
    Mar 2012
    Fourways
    Thanked: 434
    Quote Originally Posted by Blackie View Post
    This is perhaps the easiest solution and can easily be done with the IIDtool
    Rob,
    Forest Hills, KZN
    Thanked: 803
    Let me know please if you find out how.
    Mar 2012
    Fourways
    Thanked: 434
    I stand to be corrected, its a sequence on the key fob and not IIDtool
    KEYLESS ENTRY on D4 from 2010 - this information is NOT in TFM
    To disable keyless entry:
    Drivers Door open
    Key inside the car
    On the keyfob:
    press the headlamp (5) button 3 times followed by the unlock (2) button.
    Take the key out, shut door, press the keyfob lock (1) followed by the unlock (2) button. The car will lock and keyless entry is disabled.
    To enble keyless entry:
    Unlock the car
    Drivers Door open
    Key inside
    On the keyfob:
    press headlamp button 3 times followed by the lock button
    Take the key out, shut door, press door handle keyless area.
    The car will lock and keyless entry is enabled
    Rob,
    Mar 2012
    Fourways
    Thanked: 434
    Seems another option is using a faraday key bag. will have to get me one of these to keep in the RTT
    Rob,
    Vaassen
    Thanked: 11
    wouldn't keeping the key in an iron casing isolate the signal from the key? (or aluminium?)
    Thanked: 104
    Drivers Door open
    Key inside the car
    On the keyfob:
    Unlock the car
    Drivers Door open
    Key inside
    On the keyfob:
    What? No standing on your head whistling Home Sweet Home?
  10. The Following User Says Thank You to waldo_g For This Useful Post:
    Tshwanetoria
    Thanked: 747
    Quote Originally Posted by waldo_g View Post
    God save the Singh?
    Hoedspruit
    Thanked: 89
    Glad you brought this issue up Rob. I've been thinking about this issue as well, especially on my 2 Botswana trips planned for later this year. I will be traveling with my parents who has an older Prado. I will probably have to keep my key and spare key in the older Prado with the Prado's key in the tent.
    2011 Discovery 4 V8 HSE
    Bethlehem
    Thanked: 4355
    Try this
    Open the Drivers Door, and press the Headlamp button on your remote 3 times, and then press the Unlock button once. The remote needs to be inside the car, near the rear view mirror.
    Now lock the door with the remote
    Your keyless entry should now be deactivated, and you cant open the door without pressing the Unlock button.
    To re activate, just do the reverse.......open door, press the Headlamp button 3 times, followed by the Lock button once.
    KE should now be activated again
    2008 Mercedes Benz CL 500........................"Bullet" (going....going...)
    2006 Mercedes Benz C 180K........................"Sussie"
    Jul 2010
    Modders
    Thanked: 251
    Faraday cage is the answer, disabling the auto access won't stop the battery drain as the car will still see and communicate with the key.
    Range Rover Sport 5.0 SC
    Lotus 7 replica racecar.
