Help me to find the cricket in my Colt!
Results 1 to 16 of 16
    Stellenryk, Bellville
    Thanked: 290
    Default Help me to find the cricket in my Colt!
    When driving over rough areas on the roads, there is a chirr chirr (like a cricket) noise coming from somewhere on the passenger side, either where the door and pillar in the front meet or could be in the dash as well. I have taken the cubbyhole out, checked everything behind it, took the firewall cover off and checked everything there as well as the door cover and could not find any suspect!
    Anyone perhaps had a similar problem that can point me in the right direction to trace it.
    Thanks.
    Dual battery system
    57 mm freeflow system
    General Grabber AT3's
    May 2016
    Thanked: 3036
    Default Re: Help me to find the cricket in my Colt!
    Clean the door rubbers very well, then rub them with red rubber grease.
    (If it does not kill the cricket, it will at least prolong the life of the rubbers! )
    2006 VW Touareg V10 TDi
    Richardsbay, KZN
    Thanked: 13097
    Not saying it is this but also check the passenger seat- the seat adjuster that moves the seat forward or back has teeth which engages on the seat frame somewhere. That sometimes doesn't seat properly ( although seat is not loose) and vibrates.
    Had this on my Clubcab, when it happens I lean over and wiggle the adjuster on the side or move the seat forward a notch and back again.
    Walker Evans, Photographer
    Aug 2017
    Vredekloof
    Thanked: 51
    Also check the seatbelt housing. Those tension springs tend to do that
    Aug 2017
    Vredekloof
    Thanked: 51
    When it is chirping give the seatbelt a pull so that it locks. If that is the problem it should stop chirping under tension
    May 2016
    Thanked: 3036
    Try to isolate / confirm the origin of the cricket - sounds echo & reflect in a car.
    Use (or get a passenger to use) a "Redneck Stethoscope":
    Stick one end in your ear, plug the other ear, and move the open end around to identify the origin.
    (I often use this in cars to identify the origin of a noise - try it, even for preventive maintenance.
    You can hear a 'bad' bearing long before it packs up!)
    Jun 2017
    Thanked: 33
    Is it perhaps coming from inside the door? My car had the same issue. And guess what, it happened to be one of the loose washers (screw washer) that holds the speaker to the panel.
    Thanked: 290
    Clean the door rubbers very well, then rub them with red rubber ghries.
    Thanks 4E - that was my first guess as well - will clean them again and use the ghrease.
    Dual battery system
    Thanked: 290
    Quote Originally Posted by Riaan van Wyk View Post
    Will move the seat around a bit and also decline it to the back, but I have done that before with no success.
    Dual battery system
    Thanked: 290
    Quote Originally Posted by TMWSHF View Post
    I removed the door panel, removed the speaker etc, and then drove around and it was still there so doubt that it is in the door. Door rubber seems to be more likely as I did patch a broken section with a piece of black duct tape and then it was quiet for a while - will use the ghrease method on this part and see what happens.
    Dual battery system
    Thanked: 290
    The search continue! Yesterday I did:
    Moved the passenger seat backwards, backrest backwards / forwards, locked the safety belt, but did not help.
    Then I smeared the door rubber with the grease as suggested, but the cricket is still there somewhere.
    Another possible cause could be that the airbag under the dash above the glovebox, could be the culprit. Will check that out this weekend.
    Dual battery system
    Sep 2012
    Thanked: 22
    Interior light switch perhaps? If the rubber has worn through then it will be plastic rubbing on metal.
    Every dog has his day!
    1996 Pajero DOHC-24 V6 3500 LWB (my first) - Sold
    2005 Patrol 4.8 GRX (my second) - Sold
    2004 Hardbody D/C 3.3 V6 4x4 (my third) - Sold
    2006 Patrol 3.0Di to TD42T swapped GL (my fourth)
    Thanked: 290
    Quote Originally Posted by b_killer View Post
    Nope, it is definitely more towards the front where the door hinges are located, but I did check that as well as the wiring lube going into the sidewall as well.
    Dual battery system
    Sep 2017
    Why donít you try to fumigate the vehicle ? U get it your bigger hardwares
    Thanked: 290
    Serious? I take it you did not read my original post! Fumigation will not help to find a squeak!
    Dual battery system
    Melkbosstrand
    Thanked: 465
    Also check bonnet bolts.
    Had it on a Colt, one of the bolts got loose. Transferred sound through dash.
    Everybody needs to believe in something.... I believe I will have another Beer!
    Travel Blog: https://since1652.wordpress.com/
    https://www.instagram.com/since1652travel/
