Results 1 to 16 of 16
    Dec 2018
    Hillcrest
    Default VW Amarok 4 Motion Auto
    I am looking for some advice. I have a 2013 VW Amarok 4motion auto. Sometimes when i pull off the is a hard thud from the rear diff. I have replace the rear diff oil with OEM oil, this did not help. So i thought the problem may lie with the transfer case so i changed the transfer case oil but still the problem persists. What i have notice is that if when coming to a stop I pull up the hand brake, when pulling off the problem does not occur. The problem does not happen each time i pull off.
    Any advice would be appreciated.
    Jul 2007
    Putfontein, Benoni
    Thanked: 2035
    Default Re: VW Amarok 4 Motion Auto
    do they have hill hold? Possibly a binding brake shoe?
    Audi Q7 - 3l TDi - 2013 - touring car
    VW Touareg - 2005 - V10 TDI ( tow car)
    VW Touareg - 2006 - V6 TDI - play car/ wife daily
    VW Touareg - 2013 - V8 TDI - my daily beast.
    Kathu
    Thanked: 7708
    U-Joint
    Thanked: 3645
    Could be the box dropping to first when pulling away (even if the MFD shows it's in first, it's often in second)
    Try a gearbox reset
    Ignition on but don't start the car
    Throttle pedal flat to the floor and hold for 15 seconds
    release throttle
    ignition off
    key out
    Now go and test drive.
    1993 3.0 V6 Pajero - SOLD : 2001 3.2 Di-D Pajero - SOLD
    2005 Touareg R5 2.5 TDi - SOLD : 2007 Pajero LWB 3.2 Di-D
    My YouTube channel
    Touareg Manuals Google Drive Folder : Pajero Manuals Google Drive Folder
    The clever ones are being outbred & overruled by the not so clever ones. Pair that with unchecked selfishness. We are heading for a fall!
    Dec 2018
    Hillcrest
    The U joints have been check. thnat was the first thing I check because it felt the same.
    It doesn't have hill hold.
    My gearbox always goes into 1st when coming to a stop. When you come to a stop the Torque convert disengages. You can see this happen when the you watch the fuel consumption drops from about 1.2l/hr to 0.8l/hr. Took it to ZF to check the gearbox and they are happy with it.
    Dec 2018
    Hillcrest
    Will try the reset tomorrow. will let you know.
    Kathu
    Thanked: 7708
    Quote Originally Posted by IntrepidAS View Post
    Did they remove the prop shaft to check the U-Joints. Failed U-joints can sometimes be hard to identify with prop shaft on the car.
  8. The Following User Says Thank You to grips For This Useful Post:
    Thanked: 3645
    I think the amarok uses cv joints on the propshaft.
    My YouTube channel
  10. The Following User Says Thank You to MariusFourie For This Useful Post:
    Jul 2007
    Putfontein, Benoni
    Thanked: 2035
    Nope - after a previous discussion I have specifically checked that and had to get a shaft repaired for an amarok. Definitely a U-joint - not a cv like the touareg.
    Thanked: 3645
    Double checked now as well. Rear has three U-joints. Front shaft is two CV Joints.
    My YouTube channel
  13. #11
    Henties
    Thanked: 2569
    How sure are you about that? The Amarok with manual gearbox does most certainly have hill hold.
    2007 Volvo S60
    2012 FJ Cruiser
    1983 FJ60 Landcruiser -sold-
  14. The Following User Says Thank You to HugoNotte For This Useful Post:
  15. #12
    Dec 2018
    Hillcrest
    I never removed the Propshaft. Just check the U joint for play. Will drop the propshaft and see.
  16. #13
    Jul 2007
    Putfontein, Benoni
    Thanked: 2035
    also check the centre bearing for play / noise.
  17. #14
    Thanked: 10191
    Transfers case on a 4motion Auto? Without being funny Please take it to a specialist
    Gert Grobler
    VW Touareg V6 Tdi Escape; Land Cruiser 200 VX-R
    Bush Lapa Ratel 4i 1906
    Sold: Land Cruiser 200 V8 D4D
    VW Amarok PanAm V6
  18. #15
    Thanked: 3645
    My YouTube channel
  19. The Following User Says Thank You to MariusFourie For This Useful Post:
  20. #16
    Oppierotse
    Thanked: 429
    To check u-joints properly you must remove the prop shaft. Check the spline section and make sure it is sliding freely and greased. Also check the u-bolts on the axle. Make sure they are tight.
    98 Hilux 2.8D D/C 4x4
