Trailer number plate light wiring
Results 1 to 6 of 6
    Thanked: 51
    Default Trailer number plate light wiring
    All the best for 2019 Forumites.
    I need to take a boat trailer for roadworthy but need to add a number plate light before I go. The number plate light has 2 wires ( + and earth). Does anybody have a simple diagram to assist me to connect the number plate light to the existing (round truck style) tail light?
    Many thanks Mike
    Stellenryk, Bellville
    Thanked: 290
    Default Re: Trailer number plate light wiring
    Quote Originally Posted by Mikepike View Post
    Many thanks Mike
    The earthwire can be attached to the trailer chassis somewhere close to where the light is. Take the + wire to the + wire of one of the tail lights.
    Dual battery system
    57 mm freeflow system
    General Grabber AT3's
  3. The Following User Says Thank You to Blackie For This Useful Post:
    Thanked: 51
    Thanks Blackie. I thought as much but didn't realise it would be as simple as that.
    Thanked: 290
    You welcome. Just make sure the earth is done properly. I normally drill a small hole somewhere in the chassis, then sanding it a bit around the hole to get a clean steel look and then use a self-tap screw with a washer to fix it to the chassis.
    Dual battery system
  6. The Following User Says Thank You to Blackie For This Useful Post:
    Thanked: 99
    If the trailer is galvanised I wouldn't drill a hole, rather just run the earth to the tail light too.
    Do you really want to add a spot for rust to get its teeth in? Especially being a boat trailer
    Geoff Craig
    '98 Suzuki Samurai - Sami the Samurai
    '09 Toyota Fortuner 3.0 D-4D 4x4 (M)
    '10 Conqueror Comfort
  8. The Following User Says Thank You to Wave For This Useful Post:
  9. #6
    Bellville
    Thanked: 1776
    Best to run the neutral wire from the plug, as said previously.
    The numbering is typically as follows :
    EDIT : 5 and 7 is typically bridged out
