M & G Automotive did the install. Really super impressed, very very professional. Arrived on time and did everything needed. Speak to Willy is need be.
When doing the garage reno, I threw a thicker slab 2m wide in the middle, lift will be moved to ideal position withing this area, 250mm deep and 25mpa (my builders slipped up a bit here and I will add a bit of bracing to the column tops) And this just as a precaution as I will be lifting the Treg (would have been OK for my Mk5 R32, Mk3 GTi, Citi Race car or my brothers Xpolo)
My ceiling is max 3m (hence the base plate version and not the base plateless that needs a clearance of 3.7m) , so can only lift to that height, but suits my needs as not a commercial shop, just a convenience.
