Ammo box compartment
Results 1 to 17 of 17
    Nov 2018
    Default Ammo box compartment
    So Im busy with a setup on my Colt double cab. Not as nice as a drawer setup,but get to use the maximum available space for 6 ammo boxes. The frame will get 6mm ply wood on top, to create a nice big area for the kids to sleep on two diy canvas matrasses inside the load bin, while the wife and I sleep on top in the roof top tent. There will also be two compartments on the sides next to the ammo boxes, of which one will in the future serve as the dual battery storage and there will also be another compartment at the back of the ammo boxes. Frame is done, next is the wood.Will update as I go on.
ID:	513943   Click image for larger version.
ID:	513944   Click image for larger version.
ID:	513945   Click image for larger version.
ID:	513946   Click image for larger version.
  2. The Following 3 Users Say Thank You to Pierre86 For This Useful Post:
    Thanked: 39
    Default Re: Ammo box compartment
    Just make sure a DC battery will fit into an ammo box, heightwise.
    Your mind is your strongest weapon.
    Then there's.....POWER TOOLS!
    '94 LC 80 GX
    '00 Frontier 280DT 4X2
    2002 Sprite Surfer Nomad
    Nov 2018
    Thumbs up Re: Ammo box compartment
    Quote Originally Posted by steamer View Post
    There wont be a battery in an ammo box,it will sit on the side of the boxes,in one of the pix you can just see a battery on the side,but thanx for the heads up
    Thanked: 285
    It seems the boxes sit flat on the loadbay, how will you reach or move the furthest ones when the wood is ontop?
    Neil
    Nov 2018
    Quote Originally Posted by neoT View Post
    There will be an anchor point for a webbing belt,fixed to the bin at the front of the second box,then run around the last two boxes and all the way to the front through a loop,so when you pull the weebing belt,the boxes come out. At least,thats the idea
  7. The Following User Says Thank You to Pierre86 For This Useful Post:
    Helderkruin
    Thanked: 384
    Lyk goed man Pierre dit sal mooi werk.
    Wartburg.
    Thanked: 493
    Quote Originally Posted by Pierre86 View Post
    Very clever idea, good thinking.
    Simple but effective, nothing to break and disappoint you when you need it the most.
    I like
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
    Dec 2013
    Pietermaritzburg
    Thanked: 79
    Interesting idea.
    I worry the bottom surface friction might be too much for the webbing belt idea.
    Perhaps try loading the boxes with weight now, and seeing if that works before topping it.
    Else you might need to put some polymer/plastic strips down to give the boxes something to run on.
    Good luck on your build.
    Pajero Sport 2013 3.2 A/T
    Feb 2016
    Thanked: 606
    My friend did the same, but the rubberizing on the loadbin caused quite a bit of friction. He eventually added angle iron under the boxes which acts as tracks and having much less friction.
    Feb 2016
    Thanked: 606
    Something else you might want to consider for one of the boxes closest to the tailgate:
    (Post#2) https://www.4x4community.co.za/forum...75#post3543375
  13. #11
    Nov 2018
    Awesome
    Thanx for all the feedback and tips. I am a bit worried about the friction and was thinking of putting flat bar underneath to have a smooth surface,just need to figure out a way to put them on without beeing part of the frame but also be able to remove them.Maybe I should use some riff nuts
  14. #12
    Stellenryk, Bellville
    Thanked: 290
    Quote Originally Posted by MrTolbos View Post
    I used alu angle in my off road trailer and the amo boxes are sliding nicely on this.
    Dual battery system
    57 mm freeflow system
    General Grabber AT3's
  15. The Following User Says Thank You to Blackie For This Useful Post:
  16. #13
    Jun 2008
    Pietermaritzburg
    Thanked: 24
    Quote Originally Posted by Blackie View Post
    This is my slider system. 6 x ammo boxes. Also space behind frame to slot in 50 liter ultra thin upright water tank attached to the box body.Click image for larger version.
ID:	515799Click image for larger version.
    2011 I30 Huyundai platcar
    2017 Ford Ranger D/Cab 2.2 TdCi XLS 4x4 Auto
  17. The Following User Says Thank You to regmark For This Useful Post:
  18. #14
    Jun 2008
    Pietermaritzburg
    Thanked: 24
    Finished project
  19. #15
    Jun 2008
    Pietermaritzburg
    Thanked: 24
  20. The Following User Says Thank You to regmark For This Useful Post:
  21. #16
    Jun 2008
    Pietermaritzburg
    Thanked: 24
    Quote Originally Posted by regmark View Post
    The space is for my Cf50 fridge when camping and obviously slides out to meet me at the tailgate end. It also protrudes only marginally into the upper load area.
  22. #17
    Aug 2018
    Swakopmund
    Thanked: 37
    They do squeeze in, although I use a high lid then there's ample space. Click image for larger version.
