Camping tips, tricks and gadgets
Page 1 of 12 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 20 of 235
    Apr 2008
    Down under - Sydney
    Thanked: 46
    Default Camping tips, tricks and gadgets
    Hi,
    Sure you all have a few great tricks up your sleeve, which make your life easier and just if a gadget, some trick which may seem simple, can be very helpful to all, would be lekker to see.
    Here is a simple one I have done, to secure my flat bottom pot into one of the square tall wolf packs. I didn't want it slip sliding around and eventually damaging the box or the rest of the contents of the wolf pack.
    Here are some pics, quick and simple to do:
Name:	Flat Bottom pot holder.jpg
ID:	161436   Click image for larger version.
Name:	Flat Bottom pot holder2.jpg
ID:	161437   Click image for larger version.
Name:	Flat Bottom pot holder3.jpg
    Going there, doing that.....There are no shortcuts to any place worth going.....so leave NOW!
    Apr 2008
    Down under - Sydney
    Thanked: 46
    Default Camping Lights
    I had 5 Hella plugs fitted to my trailer and got 5 x Lumeno strips with 500mm or 1000mm leads with hella male and magnet strips on the rear, works very well, and can move my light around where I need it or want it. Can shine down for low light as well as sideways if required for a brighter light, just use a magnet strip as long as the light, else it may not be strong enough to hold the led on. Works a treat, here are some pics:
Name:	Lumeno with Hella and 500mm lead.jpg
ID:	161440   Click image for larger version.
Name:	Lumeno with Magnet.jpg
    Apr 2008
    Down under - Sydney
    Thanked: 46
    Default short electrical plug
    Saw this while in Kgalagadi and thought it is very useful, a short 1 to 2 extension that can be placed in the electrical box at camp sites, handy to power a fridge in the car and the trailer or caravan. Also when you find somebody else using your power point......grrrrr
    Thanked: 15
    Put your cooking oil in one or two spray bottles.
    One: you use just the right amount of oil when making breakfast.
    Two: chances of leaking while driving rough roads is much less.
    Dec 2009
    Delmas
    Thanked: 622
    Always take some jiffy bags.
    Jiffy self seel. jy kan alle oorskiet kos bere, sakkies meel wat breek in sit, vuilgoed ingooi en reuke uithou.
    Dit werk!
    Elize
    en ry saam met SarelF in
    VW AMAROK MET BLINKGATCAMPER:
    My Platkar:- Peugeot 208
    Kyk gerus by www.blinkgatproducts.com
    Vir enige aluminium produkte,canopy's, campers kontak gerus
    Sarel 0828209413
    Feb 2008
    Thanked: 2604
    After many miles on the road overlanding, I can never quite understand our obsession with ablution blocks and showers. A face cloth, a cup of hot water, and you can get clean in the most filthy conditions. It's the standard desert bath. Try it. It works. And you can brush your teeth with half a cup of water. Did I forget to add that after you've done all of that, there is nothing more important to start the day in the bush than a cup of good coffee (or tea, if that's your preference).
  7. The Following User Says Thank You to Tony Weaver For This Useful Post:
    Nigel
    Thanked: 2066
    Wipe your plates with paper towels before you wash them. The you need very little water in washing dishes.
    LC 78 Troopie 1HD-FTE
    Uniglide
    +27 zero eight 2 four 95 9252
    Aug 2008
    Rangeview Krugersdorp
    Thanked: 1021
    Tony , does the tea/coffee not taste strange using the toothpaste water ?
    Chev Aveo and Atos and Polo.
  10. The Following User Says Thank You to duncang For This Useful Post:
    Jan 2010
    Pretoria-Oos
    It's got a nice minty coffee taste
    Tips:
    Always take a roll of heavy foil with - good to use to cook vegetables in the coals, as well as to make a 'packet' for left over steak to eat the next day for breakfast.
    Take a normal clawhammer with, easy to hit in tentpegs as well as pull them out.
    2001 Land Rover Defender TD5 110
    Have a 12v energy saver light, with long cable and croc clips. With small 12v gate motor battery. I normally camp where there's electricity, but this thing is my braai light(just) throw it over an overhanging branch, bulb removed obviously) It is also there for any other thing I need light for. Swambo and kids can even take it to ablutions of the power is off.
    This thing have been hanging in rain and wind, and still works 100%.
    Light with cable, switch and clips was R46, battery R95
  13. #11
    Bethlehem
    Thanked: 3225
    I guess everyone already packs his hard booze in those 500ml dip bottles??
    2 "squirts" make a reasonable double.
    You can pack 2 x 750ml into 3 dip bottles - small, no glass, and no empty bottle.
    I sommer mark them with masking tape every time - "Richelieu" or "Gin" , "Bells", etc etc
    Of COURSE I have a Bad Habit. I take Tea at Three (Mick Jagger)
  14. #12
    Dec 2010
    Boksburg
    Thanked: 30
    Hi
    I made myself a 12v power pack that I can carry around the campsite. Use is to pump up the matrasses. Vacuum the tent, light at the braai at night and to charge the cell phones.
ID:	161505   Click image for larger version.
    "What the eyes can see, the hands can build"
  15. #13
    Aug 2008
    Thanked: 1021
    Petri,mark the one Hennessy VSOP rather. Adds class to the campsite
  16. #14
    Bethlehem
    Thanked: 3225
    No man - you cant mix that with Coke - Yak
    The best candy is a Coke with Brandy
  17. #15
    Apr 2009
    Quote Originally Posted by Davidvan View Post
    You bought the Lumeno strips complete as is with magnetic strip and lead, or did you make them up yourself? If bought as is, from where?
    Louis
    Stock standard 99 Pajero 3.5
  18. #16
    Apr 2008
    Down under - Sydney
    Thanked: 46
    Quote Originally Posted by Loehis View Post
    Hi,
    I made these up, bought some magnet strip from a stationary store and used some glue to stic to the unit. Then added the hella plugs and join and some of the black wrap, which I got from frontrunner.
    David
  19. #17
    Thanked: 21
    Took some Brandy on a school camp in STD8 in those hairspray "pump" bottles. Forgot that the pipe leading into the bottel was still full of hairspray / gell.
    Took it out and to be "cool" sprayed two or three sprays directly into my mouth. And yip it was pure hairspray!!!!!
    I guess it served me right!
    Neil
    2008 Fortuner 3.0 D4D 4x4 - The boring appliance that battles to stay upright! (Flippie)
    2002 Colt Rodeo 2.8TDI 4x4 (Smokey)
    2000 3.5 V6 SWB Pajero
    Boswa
    - since fitting Land Rover wheels it has an oil leak
    GP0049
    ORRA X129
  20. #18
    Feb 2008
    Thanked: 2604
    Hehe.
    Another camp trick of mine is I carry several fairly thick dowels and lots of S hooks (most hardware stores sell them). We stick the dowels across two tree branches, secured with cable ties, and hang whatever needs hanging on the S hooks slung over the dowels - dish clothes, cloth bags with our cutlery in them, coffee mugs, braai grids, lamps, torches, anything you want to keep off the ground and out of the dirt. Makes the camp nice and tidy. If there are no trees about, I cable tie the dowel to my roof rack struts.
  21. #19
    Bethlehem
    Thanked: 3225
    Sorry - what is a dowel??
  22. #20
    Bethlehem
    Thanked: 3225
    (double post - as above)
