BMW 1200gs grip trick
Results 1 to 10 of 10
    Thanked: 281
    Default BMW 1200gs grip trick
    I am sure there are many who know this trick, but here goes. My bikes grips were getting a bit tatty and being heated, they are hell expensive to replace. So I read on a forum to take a mountain bike tube (R39.00) cut it up and slip it over the current grips. Works a charm and looks fine. When they get tatty, rip them off and replace. Hope this helps someone.
ID:	513198   Click image for larger version.
ID:	513199   Click image for larger version.
  2. The Following 4 Users Say Thank You to Johnna For This Useful Post:
    Thanked: 281
    Default Re: BMW 1200gs grip trick
    Just a few more pointers, wash the powder out of the tube before installing, use soapy water to slide into place. The 1.5 inch diameter tube fits nicely.
    Jan 2015
    Colesberg
    Quote Originally Posted by Johnna View Post
    Even better. Go buy yourself a cricket bat grip rubber.
    Thanked: 281
    I have heard that one as well, although a few of the guys said they donít hold up well with the heated grips? Have you tried, did it work? They do look nice
    May 2016
    Thanked: 2620
    You can buy non-slip shrink sleeve for tennis rackets.
    That should work as well.
    2006 VW Touareg V10 TDi
  7. The Following User Says Thank You to 4eTouareg For This Useful Post:
    JHB - west rand
    Thanked: 293
    Quote Originally Posted by taljaae View Post
    Yep, that's what I do. R15 for a grip at sportsman's warehouse last time I bought, and lasts about a year for me.
    Chris
    Don't blow it, this is the only planet with beer!
    HYADES
    JHB - west rand
    Thanked: 293
    Chris
    HYADES
  10. The Following User Says Thank You to Hyades For This Useful Post:
  11. #8
    Krugersdorp
    Thanked: 60
    I also used Cricket bat grips. Lasted a couple of months before needing replacement
    FORD Ranger
    Conqueror Courage
  12. The Following User Says Thank You to blind For This Useful Post:
  13. #9
    Jul 2018
    Kathu
    Thanked: 63
    I second the cricket bat grips. they do not last much in the sun but will still be only R20 for a year's use. 10min to install and look good. No issues with heated grips. Or, get grip puppies. Good feedback on them and a more long term solution.
  14. #10
    Jan 2015
    Colesberg
    I've installed it a 1200 GS. I must say I hardly than ever used the heater on the grips. Those grips lasted for 5 years and I eventually sold the bike with those grips still looking fantastic. The only down side is that the cricket bat rubber does enlarge the grips of the bike a bit but you will get used to it.
    Try it. Those rubbers are not that expensive (it was R35.00 a few years back). If you don't like it, remove it and install the bicicle tube.
    Let me know what you think of it.
