Cost of maintaining a Jimny
Results 1 to 20 of 40
    Dec 2018
    Thanked: 8
    Default Cost of maintaining a Jimny
    Hi everyone,
    I am looking at getting a Jimny (2nd hand) as I find myself increasingly needing 4x4 capabilities and I'm tired of getting stuck with the i10.
    But I would like some advice from long term Jimny owners (particularly those with >200k on the clock). How is the Jimny's performance affected by age? Does the maintenance costs and fuel consumption go up significantly beyond 100k on the clock?
    I am looking at getting an older Jimny (due to financial limitations), but I wonder if the R60k discount is worth it, or will an older Jimny cost me more in the long run due to additional maintenance costs and fuel?
    Any opinions would be greatly appreciated.
    Jun 2007
    Pietermaritzburg
    Thanked: 140
    Default Re: Cost of maintaining a Jimny
    Kept our Jimny till about 130k and although not near your 200k mark we never spent anything except for regular service items, one set of tyres and a steering damper modification.
    Gen 4 Pajero GLX 3.2 DiD
    Forum Radio Licence 1037
  3. The Following User Says Thank You to Diversions For This Useful Post:
    Jan 2011
    Thanked: 569
    When you buy a Jimny, it is a never ending expenditure, then you need radial cup protectors, then you need lockers, then you need a lift kit, then you need a drawer system, etc etc etc
    Before you criticize someone, you should walk a mile in their shoes.
    That way, when you criticize them, you're a mile away and you have their shoes.
  5. The Following 4 Users Say Thank You to JCMostert For This Useful Post:
  6. #4
    Jan 2007
    Thanked: 310
    Maintenance is relatively cheap on the Jimny's. Unless as JCMostert implies, the bug bites and you end up in the never ending modification cycle.
    Vic
  7. The Following User Says Thank You to saxj For This Useful Post:
  8. #5
    Dec 2018
    Thanked: 8
    Thanks for all the replies so far.
    I will definitely be getting into the mods at some stage, but those will be optional expenses if and when the funds become available.
    In terms of the Jimny's services, what do these typically cost?
    And except for the reduction in fuel efficiency associated with some of these mods (larger AT tires and roofrack), does the Jimny's fuel consumption worsen with age or does this remain fairly constant if properly maintained?
    I apologise if these are silly questions, but on a student budget every rand counts.
  9. #6
    Apr 2012
    Thanked: 49
    Mine has seemed Pretty constant, other than fuel increasing slightly after fitting bigger tyres. I dont have a lot of mileage on the vehicle but, I have not had any issues, besides having to cut a bit after fitting other tyres.
    Last Major Service(From Suzuki):
    Gasket - 9.12
    4 Plugs - 128.28
    Air Filter - 292
    Oil Filter - 82.37
    Oil - 200
    Labour - 782
    Total: R1717.83
    Which is practically a major service, other than wear and tear items like brakes etc
    This was a year ago, so might be slightly more now.
    Probably one of the better 4x4s on Maintenence costs.
    As for Fuel consumption, I wish it were a bit better, I get 10km/L but thats because of my driving style
    2014 Jimny with some Bits & Bobs
    Made By Suzuki Tweaked by Kril
  10. The Following User Says Thank You to ...kRiLLiN... For This Useful Post:
  11. #7
    Mar 2016
    Thanked: 1914
    Jimny cant be expensive.
    It is then so small, like a platkar
    Yes, I'm stirring
  12. #8
    Thanked: 1188
    Quote Originally Posted by ...kRiLLiN... View Post
    Gasket - 9.12
    4 Plugs - 128.28
    Air Filter - 292
    Oil Filter - 82.37
    Oil - 200
    Labour - 782
    Total: R1717.83
    Nothing wrong with that consumption.
    Sent from my iPhone
  13. #9
    Thanked: 10248
    Quote Originally Posted by Oppies3800 View Post
    Yes, I'm stirring
    yes, so cute, almost like a real 4x4............
    definitely stirring
  14. The Following User Says Thank You to jelo For This Useful Post:
  15. #10
    Apr 2012
    Thanked: 49
    Its probably kinda AVG for a Jimny, but I always thought its a bit much for a 1.3.
    Power to weight I guess. I reckon, you could get better consumption with a more powerful motor, like a 1.6 or 1.8
  16. The Following User Says Thank You to ...kRiLLiN... For This Useful Post:
  17. #11
    Pta
    Thanked: 7
    Hi Pandafish
    I reckon with my Jimny at 294k km it will give you a good idea on the maintenance cost on it.
    List of repairs and normal wear :
    Clutch x2, Gearbox fixed and later replaced with second hand one, outlet manifold - replace with full free flow, Wheel bearing rear x2, Cylinder head replace with second hand one(this was my own fault), Tyre's x 3 times, Coil pack x1, Dead wobble repairs on going and services since new after warrantee serviced it myself.
    Cost about R117950 that gives you close to 39c per km on maintenance this is excluding fuel cost if I am correct.
    Fuel consumption is on average 11km/l
    Niekie
    Suzuki Jimny 2010 met n paar goed gedoen
  18. The Following 2 Users Say Thank You to Niekie For This Useful Post:
  19. #12
    Dec 2013
    Paarl
    Thanked: 506
    Not the best example as i have nit done a lot of kilos yet.
    Just had second oil service. R1750.
    First service was also about that.
    Currently running around 11km to a litter.
    All extra costs was also included and loaded onto fuely and thus extras cost included for the tupperware for underbody armour and all round bout R5000 for extra costs.
    So fuely stats include fuel as well as expenses and services that up to now seem to be running cost of 1.31 per kilo.
  20. #13
    Sep 2017
    Thanked: 114
    Just a thought.
    By fitting larger tyres the odometer will underread. The lower reading will influence the calculation of your fuel consumption figures.
    This reflects a higher fuel consumption compared to the previous tyres that had a smaller diameter although the actual distance is constant.
  21. #14
    Benoni, Gauteng
    Thanked: 43
    Hi,
    For your reference, I purchased my Jimny 5 years and 2 months ago with 102k on the clock.
    I clocked over 200k on Thursday travelling back from Sabie. In the 5 years and almost 100k km, this is what I have had to repair aside from regular servicing -
    1 x coil pack (to sort out a miss at idle) +- R500
    1 x gearbox rebuild (to sort out a very bad whine, failed bearing - 175k on clock) +- R8k
    1x clutch (replaced at gearbox removal as a precaution) +- R1.5k
    1 x windscreen (cracked by rocks from an 18 wheeler) +- R1.5k
    As most people who know me will confirm, I do use my vehicle regularly, and heavily, off road. So she has had a harder life than most.
    I do not believe that this is bad at all for the time / mileage that I have covered. She is still going storng, with her original engine, and all is well.
    Eric L
    ME_______ - '09 SUZUKI JIMNY - Pipe Bumper / Under body Protection / Winch / Snorkel / Roof Rack / VHF+UHF Comms
    SWAMBO__ - MAHINDRA BOLERO - Feels like an SJ / loads like a truck / tows like a tank!
    RETIRED___ - '99 Gen 1 Grand Vitara / 1.6 Vitara JLX ...x2 / SJ413 SWB ...x3 / SJ413LWB ...x1 / SJ410 ...x2.
  22. The Following 2 Users Say Thank You to Ericl For This Useful Post:
  23. #15
    May 2015
    Straight outta Benoni
    Thanked: 444
    Yes, I'm stirring
    I think the Jimny is probably one of the cheapest '4x4's' to run...then you have Landrover, where I have had to sell a few of my own internal organs on the black market to be able to afford.
    Quote Originally Posted by Pandafish View Post
    The only silly question you can ask on these forums is if you should add 2SO to diesel.
    Last edited by Naes-Landy; 2018/12/24 at 01:40 AM. Reason: Extra reference to the ongoing 2SO saga.
    1998 Defender 90 TDi 300 for Africa.
    2014 Ford Fiesta 1L EcoBoost petrol for Europe.
    Swambo and I have a little travel blog: https://www.thetravellingchilli.com
  24. #16
    Dec 2018
    Thanked: 8
    Firstly, I would like to wish everyone a happy and prosperous new year!
    Then I'd like to thank everyone for the valuable information provided here, in particular Niekie, Johan65 and Ericl for detailing their running costs.
    After a lot of thought and deliberation, including many hours scouring the threads of this forum, I have my heart set on the Jimny and I think I might have already found the one for me .
    Thanks again for all the informative responses, hopefully I'll be taking on 2019 in a Jimny...
    Dewald
  25. The Following 2 Users Say Thank You to Pandafish For This Useful Post:
  26. #17
    Dec 2018
    Thanked: 8
    Quote Originally Posted by DdeJ View Post
    Just a thought.
    What would be the most accurate way to measure distance traveled in the Jimny?
    I've read a lot of complaints regarding the accuracy of the Jimny's odometer (even without larger tires)
  27. #18
    Dec 2018
    Thanked: 8
    "The only silly question you can ask on these forums is if you should add 2SO to diesel." - Naes-Landy
    Should I?
  28. #19
    Hillcrest, Malaysia
    Thanked: 5979
    Just a thought.
    You may want to think that thru again.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
  29. #20
    Jan 2007
    Thanked: 310
    Not succinctly stated, but 100% correct.
    Larger tyres mean your odometer will show less distance than actual.
    Vic
