Cost of maintaining a Jimny - Page 2
Page 2 of 2 FirstFirst 1 2
Results 21 to 40 of 40
  1. #21
    Dec 2013
    Paarl
    Thanked: 506
    Default Re: Cost of maintaining a Jimny
    Not succinctly stated, but 100% correct.
    Larger tyres mean your odometer will show less distance than actual.
    Correct but correlation is not 100% directly. Many have done tests with gps distance and fuel usage and here it still showed that bigger tires influance fuel usage and result in more l/100km.
  2. #22
    Dec 2013
    Paarl
    Thanked: 506
    Quote Originally Posted by Pandafish View Post
    I've read a lot of complaints regarding the accuracy of the Jimny's odometer (even without larger tires)
    Never heard of all these complaints. 99% of cars speedo is showing a little faster then actual gps speed.
    Use gps and you will find actual speed easily to compare.
    My jimny speedo at 120 normally is 115 on gps.
  3. #23
    Hillcrest, Malaysia
    Thanked: 6516
    Now lets put the shoe on the other foot.
    With larger tyres, for a given odometer reading, you are travelling further, so you fuel consumption is actually better than you indicated/calculated fuel consumption.
    In real terms it could actually be better or worse, depending on a whole heap of things.
    For a given set of speed and conditions there is a final gearing setup that the manufacturer will try to provide the best combination of performance and fuel consumption. Specialised vehicles may sacrifice performance for fuel, and vice versa.
    My rule of thumb is that moderately or under powered vehicles will get worse fuel consumption with larger tyres and excess or high power vehicles could very well get better fuel consumption with larger tyres.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  4. The Following 2 Users Say Thank You to Fluffy For This Useful Post:
  5. #24
    Jan 2007
    Thanked: 328
    In the Jimny's case the consumption is definitely worse with even slightly bigger tyres, but calculating the consumption using the odometer makes it look a lot worse.
    Vic
  6. The Following User Says Thank You to saxj For This Useful Post:
  7. #25
    Jul 2018
    Durban Hillcrest
    Thanked: 40
    yes, so cute, almost like a real 4x4............
    definitely stirring
    When it grows up it will be a real 4x4
  8. The Following User Says Thank You to nigelgeast For This Useful Post:
  9. #26
    May 2015
    Somewhere
    Thanked: 619
    "The only silly question you can ask on these forums is if you should add 2SO to diesel." - Naes-Landy
    Should I?
    Short answer: No
    Long answer: ungalokothi empilweni yakho
    A sure sign that there is in fact intelligent life elsewhere in the universe is that none of it has bothered contacting us.
  10. #27
    Apr 2012
    Thanked: 49
    The Jimny overeads by about 5-6km/h on stock wheels 205/75/15, I tested this with multiple GPSs and get the same results. On 215/75/15 I get a spot on accurate reading, and I have seen and heard of multiple people with the same results, local and abroad. So yes, in the same breath that fitting bigger tyres will reduce your consumption slightly, it will also give you a more accurate reading. So technically the actual mileage that you get with stock wheels is not really correct. The fuel consumption drop when fitting 215s is minimal in my opinion. If you take your current mileage that you get on a tank with stock wheels, and reduce it by 5%, you should get a better estimate of the actual mileage that you getting.
    2014 Jimny with some Bits & Bobs
    Made By Suzuki Tweaked by Kril
  11. #28
    Thanked: 1450
    Quote Originally Posted by ...kRiLLiN... View Post
    I also get an accurate reading on 215/75.
    Sent from my iPhone
  12. #29
    Sep 2017
    Malmesbury
    I’m off by 2-3 km/h with 205/75s so could very well be spot on also with 215/75s.
  13. #30
    Dec 2018
    Thanked: 8
    One last question...
    The manual specifies one should use 95 unleaded (also indicated on the fuel cap lid), however, a colleague of mine is certain that at higher altitudes. Since we are both biologists, I don't take him to serious, but he raises a relevant question.
    What fuel type do you guys use for your Jimny's and has anyone noticed a difference between 93 and 95? (other than the price...)
    I have also attached an image of my new travel companion
    Last edited by Pandafish; 2019/01/07 at 05:04 PM. Reason: Initially attached the wrong image...
  14. The Following User Says Thank You to Pandafish For This Useful Post:
  15. #31
    Dec 2014
  16. #32
    Jun 2017
    Thanked: 62
    Tried both 93 and 95. No difference in fuel consumption or power. I'm in Pretoria so just use 93.
    Suzuki Jimny 2017
    Radical cups
    Steering damper
    Front Runner roof rack
    Floor board
  17. The Following User Says Thank You to Alexaj For This Useful Post:
  18. #33
    Jul 2015
    Thanked: 57
    Same here, used 93 for 2 years, then tried 95 for 3 months. No difference. Now back to 93. I do however like to throw in 95 when I'm pulling a trailer or loaded to the brim.
    Andreas Naudé
    Current Vehicle
    Good Year Wrangler Adventurers 205/75 R15
    Neotrek Little Swift roof rack
  19. The Following User Says Thank You to Andreasjsn For This Useful Post:
  20. #34
    Nov 2011
    Hartenbos
    Thanked: 383
    Quote Originally Posted by Alexaj View Post
    I'm curious, why you would expect a change in power or fuel consumption? The octane rating of fuel is an indication of its detonation characteristics, not its calirific value.
    When you correctly setup engine is detonation regularly move up in octane rating. If not, no need to change.
    Cobus
    2010 Jimny
  21. #35
    Jan 2007
    Thanked: 328
    Quote Originally Posted by jab2 View Post
    To compensate for knock, the ecu would need to alter the timing, which would translate to a change in performance / fuel consumption. If there is no change in performance or consumption, the ecu probably didn't need to make the compensation. Calorific value as Jab2 states is likely the same so there should be no difference.
    Vic
  22. The Following 2 Users Say Thank You to saxj For This Useful Post:
  23. #36
    Benoni, Gauteng
    Thanked: 46
    Confirm, I've used 93 exclusively since I purchased my vehicle, and no issues, no problems. Only time I put in 95 is when I'm at low altitudes and 93 is not available. Vehicle on 200K + km now with no issues.
    Eric L
    ME_______ - '09 SUZUKI JIMNY - Pipe Bumper / Under body Protection / Winch / Snorkel / Roof Rack / VHF+UHF Comms
    SWAMBO__ - MAHINDRA BOLERO - Feels like an SJ / loads like a truck / tows like a tank!
    RETIRED___ - '99 Gen 1 Grand Vitara / 1.6 Vitara JLX ...x2 / SJ413 SWB ...x3 / SJ413LWB ...x1 / SJ410 ...x2.
  24. The Following User Says Thank You to Ericl For This Useful Post:
  25. #37
    Thanked: 1450
    Just a side note, I serviced my Jimny at the dealer (75 000km service) for R1200.... Now that is cheap!
    Sent from my iPhone
  26. The Following User Says Thank You to Rebel 4x4 For This Useful Post:
  27. #38
    Jun 2017
    Thanked: 62
    What did it include?
    Suzuki Jimny 2017
    Radical cups
    Steering damper
    Floor board
  28. #39
    Cape Town Southern Suburbs
    Thanked: 1134
    If that is a major service and not just an oil service that is very good.
  29. #40
    Dec 2010
    Durbanville, Cape Town
    Thanked: 12
    My first service (covered by motor plan) was also R1200. Was oil filter, oil and a gasket and labour.
