Canopy: Beekman vs Andy Cab
Results 1 to 11 of 11
    Jul 2010
    Randburg
    Default Canopy: Beekman vs Andy Cab
    Hi
    I am trying to decided which canopy to buy for my Amarok Double Cab:
    Beekman Executive or Andy Cab Platinum
    points to consider:
    practicality in the rain
    best fuel consumption
    durability
    access
    visibility
    please throw some opinions at me?
    Gav
    Thanked: 928
    Default Re: Canopy: Beekman vs Andy Cab
    I had both, and will choose Beekmsn every time. My Beekman was solid as if made from steel. I never trusted the Andy Cab the way it flexed in the upper corners of the tailgate.
    Having said that, I am not familiar with the models you refer to.
    Youth is such a wonderful thing - what a pity it is being wasted on the young.
  3. The Following User Says Thank You to Poen For This Useful Post:
    Sinoville Pretoria
    Thanked: 389
    Quote Originally Posted by Slabeye View Post
    Hi
    points to consider:
    durability
    access
    visibility
    Gav
    Your canopies use fuel?
    Henk Pretorius D4 3,0 SDV6 HSE
    EX AFRICII SEMPER NOVUS
    Feb 2012
    Secunda
    Thanked: 126
    I had a Beekman.
    Very good canopy
    Thanked: 23
    Why glass fibre canopies..when aluminium canopies offers much more practicality...have a look at Rino or Ekoveld alu cabs. Even RSI make good ones.
    Alucab is expensive though!
    Jannie Engelbrecht
  7. The Following User Says Thank You to Jannie Engelbrecht For This Useful Post:
    Feb 2012
    Secunda
    Thanked: 126
    Many use fibre glass due to aluminium being much more expensive
    May 2014
    Tshwanetoria
    Thanked: 343
    Quote Originally Posted by Jannie Engelbrecht View Post
    Even RSI?
    Mar 2017
    Thanked: 32
    @Slabeye
    Sent u a pm
    Jul 2010
    Randburg
    Visibility, seeing out of the canopy.
    Aug 2008
    Secunda
    Thanked: 11
    Fitted a Beekman High rise canopy on the Chev Utility.Need head room in canopy and had the roof reinforced for more safety.First canopy was bad fitted and leak dust and water. Beekman replaced the canopy with an new one that was fitted at my home on there costs and it was fitted properly. No problems after one year.Very good after sales service.
  13. #11
    Vanderbijlpark
    Thanked: 245
    My Beekman leaks something crazy. The tonneau cover when it's fitted stays much dryer in the loadbin.
    Stationary, standing in the rain the water runs into it and it looks like the windows are the main culprit.
    2009 Hilux 3.0D4D D/C 4X4, Dual battery, ARB Bar, Winch, Home made rock-sliders, EFS Suspension, IPF Spots, Stofpad rear bumper.
