What pipe is this?
Results 1 to 9 of 9
    Jul 2018
    Thanked: 26
    Default What pipe is this?
    Hi guys. I'm hoping one you more mechanically minded guys can help me out. 2 days ago my freelander 2 started sounding like a swarm of bees under the bonnet, today I started noticing a distinct lack of power. The noise gets worse just under 2000rpm. Opened the cover up and saw a big cut in the hose in the Pic. It's going in to the repair shop, but I would like to know what this is and what it does before being told by the grease monkey (no offense, some grease monkeys are great people). Also, is it just general wear and tear that causes it or is a symptom of some bigger issue. Thanks in advance.
ID:	512430   Click image for larger version.
    Jan 2015
    Vredenburg
    Thanked: 935
    Default Re: What pipe is this?
    That appears to be a crank case oil breather pipe.
    But it's difficult to see where it starts and connects you under the manifold.
  3. The Following 2 Users Say Thank You to Karoo Klong For This Useful Post:
    Thanked: 10200
    EGR pipe from exhaust to intake is my guess.
  5. The Following User Says Thank You to jelo For This Useful Post:
    Forest Hills, KZN
    Thanked: 712
    Never seen or heard of an issue with that 'pipe' in my years of owing one or researching one. Looks like EGR pipe.
    Whatever it is it's leaking bad...
  7. The Following User Says Thank You to douglash For This Useful Post:
  8. #5
    Jul 2018
    Thanked: 26
    Did some googling on the suggestions above. Its the crank case breather hose. Thanks for the help, it doesnt seem like a massive job to replace it (i hope), access to the other end may be the only issue. It is a 2007 vehicle, so i would expect some rubber and plastic to degrade over that time.
  9. The Following 3 Users Say Thank You to RJay For This Useful Post:
  10. #6
    Thanked: 194
    Quote Originally Posted by RJay View Post
    Yup crankcase breather pipe. Not the original clamp so its been forced off before probably damaging it then. Not very hard to replace. I would suggest you replace the silly Land rover crimp clamps on the other ends with proper hose clamps like in your picture.
    2005 Land Rover Discovery 3 V8 (Will allways end up with an V8)
    1967 Land Rover Series 2A 3.5 V8 (The Green Machine)
    196? Land Rover Series 2 V8 100" (The Coiler)
    2007 Subaru Forester XT 2.5T (The Daily)
    Ex.
    1996 Land Rover Discovery 1 Tdi
    1997 Land Rover Discovery 1 V8
    2001 Land Rover Discovery 2 V8
    2006 Land Rover Discovery 3 TDV6
    2007 Land Rover Freelander 2 TD4
  11. #7
    Feb 2012
    Thanked: 58
    Just wondering why there would then be a lack of power as per OP.
    Gary W
  12. #8
    Jul 2018
    Thanked: 26
    im not sure why, maybe it messes up some sensor? Ive come to realize that with this FL2, there seems to be more sensors than car sometimes.
    Im sure its worse (more cpu's and sensors) in the range rovers
  13. #9
    Jhb East Rand
    Thanked: 13
    My 2c : depending on how the system is deigned a torn breather hose could result in a small or large vacuum leak.
  14. The Following User Says Thank You to Daen For This Useful Post:
