Deterrent for monkeys and baboons - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 46 of 46
    Sep 2018
    Default Re: Deterrent for monkeys and baboons
    Works the same as with security at your home - you must just be better protected against burglars than your neighbours.
    A kettie works well when camping for a longer period. At Namushasha on the Kwando one uses the kettie to scare away the monkeys on day one and two - thereafter they give you a wide berth.
    Monkeys enter a caravan tent from underneath through the skirtings. We used a large second-hand canvass to make a one piece ground cover and skirting for our Oryx caravan -ensure that the tent canvas is secured with tent pegs and door zips are secure with small D shackles and viola – your neighbour entertains the monkeys.
    It also helps to lock all the food in the caravan
  2. #42
    Thanked: 228
    We lock our food in a padlocked Tin Trommel/trunk ..Problem doesnt exist
  3. #43
    Aug 2008
    Thanked: 37
    Baboons once trashed my locked bar fridge beyond repair at Pilanesberg.
    There were only a few beers & cokes inside it.
    They did not manage to open it. So out of frustration they can wreck any locked box, I'm sure.
    Your mind is your strongest weapon.
    Then there's.....POWER TOOLS!
    '94 LC 80 GX
    '00 Frontier 280DT 4X2
    2002 Sprite Surfer Nomad
  4. The Following User Says Thank You to steamer For This Useful Post:
  5. #44
    Aug 2008
    Rangeview Krugersdorp
    Thanked: 805
    An easy idea Name:  IMG-20181220-WA0004.jpg
    Chev Aveo and Atos and Polo.
  6. The Following 2 Users Say Thank You to duncang For This Useful Post:
  7. #45
    Garsfontein
    Thanked: 388
    LOL, I came here to post this!
  8. The Following User Says Thank You to supersunbird For This Useful Post:
  9. #46
    Apr 2017
    Scottsdale
    Thanked: 16
    Back in October, I was driving my Defender alone in Chobe National Park and stopped at the picnic area where the safari guides usually stop around 9am for coffee and biscuits. I had the passenger seat window down and the second I stopped a fairly large monkey jumped right on to the door opening. I yelled at it and it immediately lunged at me, showing teeth and screeching at me. I had just picked up a large water bottle for a drink and instantly whacked it right in the mouth. It took off and didn't return, but I could tell by the number of them that were almost directly underfoot that the tourists had probably been feeding them for a long time.
  10. The Following User Says Thank You to Az2Africa For This Useful Post:
