DC-DC Charger Earthing
Results 1 to 3 of 3
    Aug 2016
    Thanked: 42
    Question DC-DC Charger Earthing
    Greetings!
    With my limited knowledge in Electricity, Advice is needed for the earthing/ negative connection to my DC-DC Charger.
    2 Diagrams below indicate option 1 & option 2. Both of them work (I have tested it briefly) however I do not want to use my bakkie as an accidental fire lighter.
    Your feedback will be appreciated.
    Witbank
    Thanked: 164
    Default Re: DC-DC Charger Earthing
    Both works the same so it does not matter.
    What sometimes does become a problem is the chassis conections. They corode and become troublesome.
    Rather just run seperate wires to both positive and negative-but purely from a long term reliability/fault finding.
    Remember to fuse both sides of the positive wires close to the batteries on each end.
    Gerhard
    Jeep Grand Cherokee WK2
    Mercedes GLA 2.0 diesel (SWAMBO)
    And a Summit Everest trailer that SWAMBO loves.
  3. The Following User Says Thank You to WillysCJ For This Useful Post:
    Nov 2008
    Ellisras
    Thanked: 298
    For these installations dedicated wiring for both + and - connections is best.
    Especially if your installation has distance between the components.(not all clustered together in engine bay)
    So your option 2 is the way to go
    2000 Patrol GU 4.2D(onkey) beyond 818 000 km
  5. The Following 2 Users Say Thank You to Dungbeetle For This Useful Post:
