Defender Defender Td5 breather
Results 1 to 5 of 5
    Oct 2014
    JHB
    Thanked: 20
    Default Defender Td5 breather
    Howzit guys
    I've tried searching the forum without luck...
    The breather pipe on my Td5 is showing signs of age and needs to be replaced.
    Can I replace this with a normal high pressure hose, or must it be genuine/Britpart etc.
    The hose I'm looking to replace is number 12.
    Sep 2014
    Thanked: 40
    Default Re: Defender Td5 breather
    Normal hose will be fine
  3. The Following User Says Thank You to Duke1098 For This Useful Post:
    Thanked: 1204
    A normal hose will be fine but then you have a problem because the cover will not fit properly, the straight, new hose will not bend the correct way to suite the cover.
  5. The Following User Says Thank You to NewLandy For This Useful Post:
    Thanked: 13573
    I'd rather go to a hydraulic shop and get hose that is impervious to hydrocarbons........
    Mar 2015
    New Germany
    Thanked: 488
    Think it made by Parker you can use push lock hose
    2005 Defender TD5
  8. The Following User Says Thank You to clivemd For This Useful Post:
