MediaRelease: Mercedes-Benz launches the range-topping X-Class V6
Results 1 to 7 of 7
    Default Mercedes-Benz launches the range-topping X-Class V6
    Mercedes-Benz Vans South Africa launches the range-topping X-Class V6
    CAPE TOWN – Whether city traffic, twisting country roads, steep gravel tracks, or gravel roads, the X-Class impresses with its outstanding dynamism, assertiveness, and stylish appearance. With a powerful six-cylinder engine, 7G-TRONIC PLUS automatic transmission, and 4MATIC permanent all-wheel drive, the new X350d 4MATIC flagship model develops 190 kW and a peak torque of 550 Nm.
    The tough performance double cab completes the sprint from 0 to 100 km/h in 7.9 seconds. Permanent all-wheel drive ensures high levels of driving stability and handling dynamics both on and off the road. With a choice of engine and transmission response levels at the driver’s fingertips, from comfortable to sporty, the X350d 4MATIC offers the perfect blend of sportiness and practicality for an agile life packed with variety. Add the prestige and status of it being a Mercedes-Benz – voted as the “world’s most valuable premium vehicle brand for 2018” – and the result is quite simply the most powerful double cab on the market.
    The Mercedes-Benz X-Class
    The demand for midsize double cabs with typical passenger car characteristics and comfort features has been steadily on the rise for years. At the same time, the number of double cabs for private use is increasing. They are no longer viewed purely as "workhorses".
    As the first premium manufacturer, expect Mercedes-Benz to lead the way once again, having flexed itself from commercial and off-road vehicles such as the Unimog and the G-Class for "tough work" to the V-Class and Vito, which are equally suitable for work or leisure. Our passenger cars have uniquely stood for modern luxury and pure exhilaration around the world. When it comes to double cabs, however, the four-cylinder X-Class ushered in the premium segment, and now, with the X-Class V6, the three-pointed star is aiming straight for executive-level business-owners, families with an affinity for premium products, trend-conscious individuals, as well as sporty and enthusiastic adventurers.
    Superior performance and fast gearshifts
    The 3.0-litre six-cylinder diesel engine with common-rail direct injection impresses with its sheer assertiveness. Its maximum torque of 550 Nm is available over a wide engine speed range from 1400 to 3200 rpm. This means that high torque is already available from low engine speeds. Whether for a sporty driving style, comfortable long-distance touring, or off-road driving in difficult conditions – the V6 always ensures serene and efficient progress.
    The 7G-TRONIC PLUS automatic transmission included as standard, complete with steering wheel shift paddles, operates with no interruption during gear changes. The wide gear spacing allows an individual driving experience via the DYNAMIC SELECT system.
    DYNAMIC SELECT for an individual choice of driving characteristics
    With a choice of five driving modes, the engine response can be changed by fingertip control – from relaxed and comfortable to sporty and dynamic.
    Comfort: This mode is activated automatically when the engine starts. It provides comfort, emphasising harmonious accelerator characteristics as well as early shift points.
    Eco: 7G-TRONIC PLUS changes the gears at particularly low engine speeds.
    Sport: The engine responds more immediately to throttle input. The automatic transmission makes use of the entire engine speed range to change gears, and shifts at higher engine speeds.
    Manual: The automatic transmission can be manually operated using the gearshift paddles on the steering wheel. This leads to far shorter shift times than in the Comfort and Eco programmes.
    Off-road: This mode is suitable for driving on challenging terrain. It offers higher shift points and a flatter, and therefore more precisely adjustable, accelerator characteristic curve.
    The ECO start/stop function is available in all driving modes except Off-road mode.
    4MATIC permanent all-wheel drive for driving on and off the road
    The 4MATIC permanent all-wheel drive with low-range reduction gear and differential lock on the rear axle ensures excellent performance and traction on a wide range of driving surfaces.
    There are three all-wheel-drive modes to choose from: 4MAT for increased vehicle dynamics, 4H for improved traction off-road, and 4L for tough off-road terrain. With the all-wheel-drive system and the suspension with its long spring travel and ground clearance of 222 millimetres, the X-Class V6 effortlessly climbs gradients of up to 45 degrees, fords water courses with a depth of up to 600 millimetres, and maintains its poise on inclines of almost 50 degrees.
    On-road excellence and quiet running on a par with passenger cars
    With 1632 millimetres at the front and 1625 millimetres at the rear, the X-Class V6 has a wide track, providing the ideal prerequisites for optimum driving stability and higher cornering speeds. At 3150 millimetres, the wheelbase is also longer than in many midsize double cabs. This reduces vibrations during the journey and makes for smooth and reliable straight-line stability.
    With an anti-roll bar to reduce body roll, coils springs fitted to the axle to balance the comfort of suspension, and shock absorbers designed to be flexible in generating counter-balancing forces, the X-Class V6 offers its passengers a level of refinement on a par with the V-Class people carrier.
    Comprehensive range of safety equipment
    The X-ClassV6 features a comprehensive array of comfort and safety features seldom seen in this segment. The basis for the high level of occupant protection is provided by the particularly robust body shell with its high-strength passenger cell, plus a structure whose front and rear sections are able to absorb energy by specific deformation.
    For passive safety, the standard equipment includes seven airbags and the i-Size attachment system for two child seats. With optional Active Brake Assist and Traffic Sign Assist , two driver assistance systems are at the ready to simultaneously increase active safety and comfort. Additionally the X350d 4MATIC – as the top model of the X-Class –also features Active Lane Keeping Assist as an option.
    Two equipment lines for the X 350 d 4MATIC
    The X 350 d 4MATIC is available in the equipment lines PROGRESSIVE and POWER, both of which set new standards for comfort and perceived value in the midsize double cab segment.
    The PROGRESSIVE line includes the following as standard: 17-inch 6-spoke light-alloy wheels, air vents in electroplated silver chrome, leather-lined steering wheel and parking brake, the infotainment system Audio 20, and an eight-speaker system.
    Standard features in the high-end equipment line POWER include a simulated, chrome-plated underride guard in the front bumper, a chrome-plated rear bumper, 18-inch 6-spoke light-alloy wheels, LED High Performance headlamps, electrically adjustable seats, and the infotainment system Audio 20 with a multifunctional touchpad.
    Optional extras and extensive range of accessories for individual character types
    Mercedes-Benz Vans has designed an extensive range of accessories so that users can customise their individual X-Class V6 vehicles even further. If required, the design, functionality or off-road capability can be enhanced to suit specific needs. In addition to the new sports bar, which can be combined with a roll cover in black or silver, there is a choice of styling bar, hard cover, hardtop, stowage box, load bed liner, load-securing rails in the load bed, and an underguard protector.
    The Mercedes-Benz X-Class V6 is now available to order. To configure your Mercedes-Benz X-Class V6 and for more information on the vehicle and authorised retail outlets, log on to www.x-class.co.za.
    This premium market contender is now available at the below prices:
ID:	511672   Click image for larger version.
ID:	511673   Click image for larger version.
ID:	511674   Click image for larger version.
    Default Re: Mercedes-Benz launches the range-topping X-Class V6
    Rather buy a Iveco dubble cab ! Propper 4x4
    2004 Defender TD5
    1992 Defender 3.5V8
    PROJECT OVERHAUL http://4x4community.co.za/forum/show...oject+overhaul
    Swakopmund
    2014 Land Cruiser 76 V8 SW
    1994 Defender TDi 200
    Drive it like you stole it!!
    Oct 2008
    Montanapark Pretoria
    I so hope this will be available some day in the V6...
    "A day without laughter is a day wasted"
    M.Benz GL350CDi Be AMG 8) AKA "worshond"
    KTM 1190R Adventure
    Oct 2008
    Something else, AFAIK this is the same V6 engine used in the GL350CDi (one I have) although the nm output is lower, WHY?
    KTM 1190R Adventure
    May 2010
    Ruimsig
    I must say even at that crazy price this is desirable.
    The comparable VW does not have the premium feel of a similar SUV.
    I hope this one does.
    Dash Fibre: Doing internet differently, drawing customers with best price, keeping customers with best service.
    Oct 2018
    Quote Originally Posted by johannes14 View Post
    Or a UNIMOG Doublecab!!! The real Mercedes 4x4.
