BF Goodrich size difference
Results 1 to 4 of 4
    Jan 2016
    Default BF Goodrich size difference
    Hi, I currently got BF Goodrich A/T 30 x 9.5 R15 fitted to my Hilux D4D, what difference would it make in steering/handling/fuel consumption if I were to replace all with BF Goodrich A/T 31 x 10.5 R15? One size bigger!
    Please if any advice would be appreciated
    Nov 2006
    Thanked: 384
    Default Re: BF Goodrich size difference
    I went from 245/75 to 31" back to 30", also KO2's.
    The main reason being that I need the extra revs in each gear because the bigger heavier tyres made the vehicle lazy.
    The extra revs are not a lot but it is noticeable.
    Also the wider tyres were on wider offset rims (also heavy) to prevent scraping when turning.
    This was very nice in sand but created a wobble on tar.
    With the bigger tyres the speedo indication was closer to gps speed than with the 30".
    Fuel consumption, I have no idea.
    Conclusion, Ive lost some height which is a real pity but I prefer the 30".
    Sep 2018
    Not too far from Pofadder
    Thanked: 187
    We have a D4D running on 31 x 10.5 R15 coopers and it runs great. cannot comment on the BF's though.
    Thanked: 176
    I have the 31 on ko1 still on the v6 and they are very good and last long, I need a new pair but where do you find old ko1? If you were here I would have said we should swap for a month or so and then check, maybe my fuel bill will go down hahaha
    Our Travel and Photography blog- https://twotracks.co.za
    The Beast - 2005 Toyota Hilux D/C 4L with freeflow
    Daily Drive- Girlfriends Honda Jazz
