VPN setup with MWEB
Results 1 to 7 of 7
    Jan 2011
    Thanked: 109
    Default VPN setup with MWEB
    Any members out there who uses a VPN with MWEB as ISP? I recently tried configuring ExpressVPN on my MWEB account using an ASUS router. The PPPoE connection seems the biggest issue, MWEB does not offer DHCP on my Octotel fiber line. The assistance from MWEB is shocking.
    Thanked: 297
    Default Re: VPN setup with MWEB
    Quote Originally Posted by Munnika View Post
    I find MWEB service shocking and useless. Pity I have them on fibre for home use.
    Roberto Forbes
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Sp Tourer
    Thanked: 2343
    I might be misinterpreting your question, but the VPN setup has got nothing to do with your ISP or router. If you can connect normally without VPN, install the VPN software on the user device and configure it there.
  4. The Following User Says Thank You to George For This Useful Post:
    Jan 2011
    Thanked: 109
    True, although I specifically bought and installed a VPN capable router (not all routers are capable, especially those cheap and nasty ones you get from your ISP). The reason I want to run the VPN on my router is to prevent configuring it multiple times over for all my devices. These devices include Smart TVs, computers and mobile devices.
    I thus want to seamlessly run (for example) Netflix on multiple devices using the VPN connection on only my router.
    Thanked: 2343
    Ah ok, have you tried this? For a Dlink, but the config should be similar.
  7. The Following User Says Thank You to George For This Useful Post:
    Jan 2011
    Thanked: 109
    Yep, exactly that. And although the config I received from ExpressVPN gets successfully installed on the router (ASUS) the moment I activate it my fiber connection drops. I've been told it's because Octotel (fiber provider) does not have DHPC connection type and only supports PPPoE. Talking to tech support for an alternative option (My ISP is MWEB) is like asking the till lady at the local SPAR for the Ouma Rooi koeksister recipe.
    Jan 2011
    Thanked: 109
    Got a call from an MWEB techy thanks to a member's intervention. Not resolved yet but at least I'm now talking to someone.
