Nat Luna Battery Pack Red Socket Problems
Results 1 to 9 of 9
    Thanked: 423
    Default Nat Luna Battery Pack Red Socket Problems
    Hi,
    So I have never had a problem with Brad Harrison plugs before and they make good contact for the most part.
    So my Nat Luna box is not charging, check fuses etc. all good. Found that by twiddling the BH plug the charging starts. However it if rather tenuous and couple of bumps on the rod and I am sure she will stop charging. My feeder from the boot to the box I have confidence in as the leads are both crimped and soldered.
    Before I open the puppy up any suggestions as to the poor contact?
    Somerset West when not in Jhb
    Thanked: 106
    Default Re: Nat Luna Battery Pack Red Socket Problems
    Check if the contacts on both plugs are hooked properly over the silver-coloured plates in the plugs.
    If corroded, undo the connections and clean with a steel brush or replace.
    I have found that different brands of these plugs have different dimensions on the actual connectors.
    ORRA Callsign: X130
    Mar 2007
    Thanked: 590
    I've had the same problem with the red plugs ...
    The added complication is that when the box looses the main battery connection and then re-connects, the timer starts all over again. I replaced the red with grey and have not had the problem since.
    Johan
    2011 Daihatsu Terios 4x4
    2018 Isuzu KB300 Double Cab 4x4 Auto
    Thanked: 106
    I don't think it is colour-related, but the replacement probably did the trick
    ORRA Callsign: X130
    Mar 2007
    Thanked: 590
    Quote Originally Posted by Subok View Post
    That is the thing ......
    I opened it up to check that all the connections were sound. Bought 2 new red ones, pulled the wires and metal pins from the old ones and inserted them into the new red plugs. Same problem. Bought 2 new grey ones. Pulled the wires and metal pins from the red ones and put them straight into the grey ones. Problem gone ......
    Can't explain it ....
    Johan
    Thanked: 106
    Electrickery voodoo! As long as the smoke does not come out!
    ORRA Callsign: X130
    Thanked: 423
    Thanks chaps, will suss it out tomorrow.
    Apr 2016
    Thanked: 47
    Hi,
    I'm intrigued that you can crimp the contact..
    Looks to me like it's made for a soldered connection.
    I would only solder. (Yes I know that if the contacts get red hot it might desolder the connection)
    What worries me about crimping is that you are deforming the contact shape.
    It's a precision plug so the less deformity introduced the better (and you can desolder the contact and use it elsewhere)
    Oct 2007
    I have had the body of a reb BH look-alike plug crack (difficult to see) The movement allowed by the crack causes intermittent/bad connections.
    Never had a grey one crack. Perhaps the slightly different shape?
    1997 Suzuki Samurai (Coily)
    1.5 inch spring lift
    30x9.5 BFG KM2 muds
    4.16 RockLobster
    2017 Ford Ranger Wildtrak 4x4
