Wrangler 2dr TJ wrangler project
Results 1 to 20 of 25
    Nov 2017
    Kitwe
    Thanked: 9
    Default TJ wrangler project
    Hi Guys,
    So I just picked up a 1997 tj jeep wrangler sahara hardtop for good money.
    It been parked out in the elements for the last two years after a failed repair job on the auto gearbox by a back yard mechanic.
    Its been neglected and hammered a bit but the engine is good and the potential huge.
    The gearbox was a quick fix lucky. The TV cable was off on the gearbox side, which probably lead to the oil and filter change and then the incorrect level check being done with the engine off meant atf was low. Connected the cable and topped up the atf and it now shifts as it should.
    The plans for now are as below:
    - 2 inch lift
    - new shocks
    - respray
    - clean clean clean
    - 17" JK rims with 265 65 r17s
    - seat lift
    - remove roof rack
    - front and rear bumpers
    - half top soft top with tonneau cover
    - fix as many rattles as possible
    It currently very jittery and unstable on the dirt. Is this part of there charm or is the suspension beyond it?
    Any other ideas to add to the list?
    Mosselbaai
    Thanked: 480
    Default Re: TJ wrangler project
    First mod on my list would be diff ratios.
    If it is a toy I would go with 33s
    Mine is surprisingly stable on dirt, your suspension must be a little tired.
    Look at all bushes when doing the lift, a death wobble is no fun.
    Jeep Wrangler TJ
    Volvo XC60
    Amarok AWD
    Nov 2017
    Kitwe
    Thanked: 9
    Looking a lot cleaner.
    Nov 2017
    Kitwe
    Thanked: 9
    Quote Originally Posted by Jeanvn View Post
    I'll stick to the 265/65 r17s which are 30.6" for now until i can do the diff ratios as i have an old set off my Ranger when I upgraded tyres.
    Mosselbaai
    Thanked: 480
    Looking good
    Jeep Wrangler TJ
    Volvo XC60
    Amarok AWD
    Nov 2017
    Kitwe
    Thanked: 9
    Milk jugs removed and new lights in. Dogs have claimed the jeep.
    Cape Town - RSA
    Thanked: 314
    Having been thinking about upgrading pops TJ with similar lights. They work ok? Worthwhile upgrade? Where did you get yours.
    Ex - 2005 Cherokee CRD
    Nov 2017
    Kitwe
    Thanked: 9
    Huge improvement over stock candles. Got them on amazon for 97. Well worth the money. Pic is of them on dim. I have a video but can't upload it here.
  9. The Following User Says Thank You to Tjkzambia For This Useful Post:
    Cape Town - RSA
    Thanked: 314
    Nice, and they look like they have proper cut off.
  11. The Following User Says Thank You to Quiksilver For This Useful Post:
    Dowerglen
    Thanked: 580
    Nice Jeep Tjkzambia, wish it was mine...
    Love your dogs!!!
    Every dog has its day, and those with broken tails have their weak-ends...
    1976 CJ-7, 400CI + Holley EFI, Tera-Low 3,15:1 twin stick, ARB's front & rear, oil leaks & plenty more....
    All my other petrol burners are boring....
  13. #11
    Maputo
    Thanked: 45
    Those rims are not going to work, 127 PCD not the same as TJ.
  14. #12
    Nov 2017
    Kitwe
    Thanked: 9
    Quote Originally Posted by Gieds View Post
    Adaptors are on there way. JK to TJ adaptors.
  15. #13
    Nov 2017
    Kitwe
    Thanked: 9
    Still waiting for parts to arrive but wheel adaptors and lift will be here this next week so fitted the tyres on the rims so i finally got an idea how they will look.
    Been busy fixing a few other issues as well. Fixed auto box leak, fixed rear brakes, several rattles and squeaks gone. Tightened up loose suspension bolts so riding a lot better now.
  16. #14
    Nov 2017
    Kitwe
    Thanked: 9
    Rims and temporary tyres on. Looks good but think the tyres will look a bit small once the lift is in.
  17. The Following User Says Thank You to Tjkzambia For This Useful Post:
  18. #15
    Nov 2017
    Kitwe
    Thanked: 9
    2" lift installed.
  19. The Following 2 Users Say Thank You to Tjkzambia For This Useful Post:
  20. #16
    Nov 2017
    Kitwe
    Thanked: 9
    Been a while since i last posted. Haven't had much time to work on the jeep.
    Dropped the auto to rebuild it and started on the body work.
  21. #17
    Thanked: 102
    Your Jeep looks decent. Are you changing the colour as well?
    D23 Navara LE Auto 4x4
    Jeep Wrangler Sahara Unlimited 75th Anniversary Edition in Sargent Green (sad to have sold it)
    Jeep Wrangler Sahara 3.6 2dr (sold)
    Jurgens XT140 (sold)
    ex VW Amarok 4motion (X3)
  22. #18
    Nov 2017
    Kitwe
    Thanked: 9
    Quote Originally Posted by 1965Landy View Post
    Trying to keep the standard colour but had paint mixed to the colour code and new paint is coming out a touch lighter. It has more silver specs verse the original gold specs. Not too worried as i'm doing a full respray.
  23. #19
    Thanked: 102
    Quote Originally Posted by Tjkzambia View Post
    The new colour is not bad.
  24. #20
    Nov 2017
    Kitwe
    Thanked: 9
    Making some steady progress.
