Tentco Bundu Canopy- please post your pics/ setup/ tips
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 79
    Richardsbay, KZN
    Thanked: 8207
    Default Tentco Bundu Canopy- please post your pics/ setup/ tips
    When I started looking at the Tentco Bundu Canopy there wasn't much available on the internet with pics of setups to look at. My mind was made up after asking here and getting favourable feedback.
    So, as a central point for pics and tips and whatever regarding the canopy please post here
    Walker Evans, Photographer
    Richardsbay, KZN
    Thanked: 8207
    Default Re: Tentco Bundu Canopy- please post your pics/ setup/ tips
    I'll start..we now use the canopy for day trips to the beach, less schlep than the big gazebo. Here I used plastic packets filled with sand as anchors but they are too flimsy when the wind blows. I have since bought some cloth shopping bags which works much better.
  3. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
    Richardsbay, KZN
    Thanked: 8207
    I use shadecloth for sides, learnt long ago that wind doesn't like solid panels.
  5. The Following 2 Users Say Thank You to Riaan van Wyk For This Useful Post:
    Richardsbay, KZN
    Thanked: 8207
    A small battery powered lantern fitted with a cable tie as light works well under the canopy.
    What I like is that I can pitch it on any two sides of the car so one can adapt to a situation. I keep the alu strip in the bag and use it when fitting to the back, fastened with g-clamps which I learnt here. When used on the side I use the main eyelet with a thick cable tie on one of the roofrack eyebolts as I have a spade bracket fitted already.
  7. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
  8. #5
    Jan 2014
    Thanked: 477
    Setup with and without sides. The sides wrap around the back pole and goes right up to the side of the vehicle. Click image for larger version.
ID:	508781Click image for larger version.
  9. The Following User Says Thank You to Daniek For This Useful Post:
  10. #6
    Richardsbay, KZN
    Thanked: 8207
    Looks good Danie!
  11. #7
    Jan 2014
    Thanked: 477
    The sides hangs on a pole that is fitted on top of the 2 corner pole. A mod that I still want to do is to fit another eye lid halfway between the the 2 side poles, on the roof that is. With that I will connect another rope to pull the roof tighter over the cross pole. That will prevent the damming of water on the roof.
  12. #8
    Strand
    Thanked: 19
    Hi Riaan
    I also wanted to have the option of using it on 3 sides of the vehicle, so I bought a length of the aluminium extrusion and mounted the correct length on each side of the roofrack.
    No G-clamps required...
    Enjoy
    His:
    2009 Pajero 3.2 Di-D GLS
    1996 Beamish Buggy SWB
    Hers
    2008 Triton 2.5 4x4 S/S - Longdistance roamer
  13. #9
    Jan 2014
    Thanked: 477
    Quote Originally Posted by JeanR View Post
    Hi Riaan
    Enjoy
    When my RTT is not installed, I also use an aluminium extrusion. However, mine is not fitted permanently. I use biggish eyelid bolts to fasten the extrusion to the feet used for fitting the RTT.
  14. #10
    Richardsbay, KZN
    Thanked: 8207
    Hi Riaan
    Enjoy
    I can't do that..Hilift jack on the one side and a spade bracket on the other side mounted on the rack. The g clamps work well for the back as I can have the alu strip overhang the rack, meaning the one side of the canopy is level with the SUV's door.
  15. #11
    Richardsbay, KZN
    Thanked: 8207
    On the sides I have to use one of the eyebolts on the rack and the back eyelet of the canopy with a cable tie.
  16. #12
    Richardsbay, KZN
    Thanked: 8207
    When using an eyelet to fasten to the rack.
  17. #13
    Sep 2018
    Thanked: 66
ID:	509022Click image for larger version.
    Got our Bundu Canopy today and must say that this is great value for the money spent. Couldn't resist to try it out. Cant wait to try all the tips on this thread to make things that much easier
  18. The Following User Says Thank You to Renier DeVilliers For This Useful Post:
  19. #14
    Richardsbay, KZN
    Thanked: 8207
    Quote Originally Posted by jimny4x4 View Post
    Money well spent indeed!
  20. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
  21. #15
    Richardsbay, KZN
    Thanked: 8207
    Like the previous poster, I also couldn't wait to put up the canopy. Same day it arrived we just had to pitch it after work, even if in the open field next door
  22. The Following 2 Users Say Thank You to Riaan van Wyk For This Useful Post:
  23. #16
    Richardsbay, KZN
    Thanked: 8207
    Trip to the harbour today, using the cloth bags now as one can load more sand in them.
  24. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
  25. #17
    Richardsbay, KZN
    Thanked: 8207
    I tie the one side to the rim, with the door open in our car it forms a sort of barrier/ privacy screen. And bit of shelter from the ever present wind by the coast.
  26. #18
    Sep 2018
    Thanked: 66
    We had n braai day at my daughters crèches year end concert/ santawith presents day and this was our first real use of our new Bundu Canopy and it was a little windy but easy to put up and down and wow really worked well. Thanks for tip to put the rope around the pole in windy conditions it worked a charm. My only regret is that we didn't get one sooner Click image for larger version.
  27. The Following 2 Users Say Thank You to Renier DeVilliers For This Useful Post:
  28. #19
    Gauteng
    Thanked: 940
    I built a rack for mine to either pitch on the car or loosen two fasteners and pitch standalone. Few seconds to remove from the rack.
    I find it very practical and intend using it a lot more.
Name:	Bundu Frame.jpg
    And carried on the side of the Roof top tent:
  29. #20
    Richardsbay, KZN
    Thanked: 8207
    Looking good!
  30. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
