Tentco Bundu Canopy- please post your pics/ setup/ tips - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 60 of 73
  1. #41
    Richardsbay, KZN
    Thanked: 8055
    Default Re: Tentco Bundu Canopy- please post your pics/ setup/ tips
    Looks good!
    Very efficient sand pegs!
    And they work on the very soft sand Paul, cheap Pick and Pay cloth bags.
    Walker Evans, Photographer
  2. #42
    Mar 2011
    Walker Bay
    Thanked: 1033
    Very good tip!
  3. #43
    My setup until I get the side panels
  4. The Following 3 Users Say Thank You to waynegrey For This Useful Post:
  5. #44
    Live : Bethal , Work : Saudi
    Thanked: 228
    Ek het n bundu canopy op my home build kamp trailer gesit
    Is mal oor die canopy hy slaan vinnig op en af en kan binne in die trailer gepak word Click image for larger version.
    One life Live it
    Take The Roads less traveled
    Alles in die lewe gebeur met n doel
  6. #45
    Richardsbay, KZN
    Thanked: 8055
    Quote Originally Posted by Haggy4x4Bedinges View Post
    It is a handy piece of kit for sure.
  7. #46
    Thanked: 228
    Quote Originally Posted by Riaan van Wyk View Post
    Yes and the misses loves it and toe just sit and relax under
    One life Live it
  8. #47
    Richardsbay, KZN
    Thanked: 8055
    If I had a proper garden with space I'd pitch it on the SUV and also just sit and relax, often I think.
    To be relatively close to the house I have to go to the parkie next door to do so, but that would just be weird
  9. #48
    Richardsbay, KZN
    Thanked: 8055
    Living where we do, it rains often and one of the only worrying things with the canopy is it's tendency to pool water. It pools so much that the weight collapses the poles which is not fun.
    Creating run off areas helps, I drop two of the sides by leaving out the poles which sorts the issue out. When fastened to the back I will drop the front ones.
  10. #49
    Richardsbay, KZN
    Thanked: 8055
    And a virreo to show it works:
  11. The Following User Says Thank You to Riaan van Wyk For This Useful Post:
  12. #50
    Richardsbay, KZN
    Thanked: 8055
    This made me realise I need another Bundu Canopy, as I got wet accessing the back of the car.
  13. #51
    Mar 2011
    Walker Bay
    Thanked: 1033
    That is good solution.
    I always keep an eye on pooling.
    I have had enough ice cold water over my head!
  14. #52
    B-gowrie Randburg
    Thanked: 205
    ... am I right in thinking this canopy
    is simply an awning
    held up & taut by up to 6 upright telescoped poles
    and attached guyropes
    with no horizontal or inclined cross-struts up-top under the canvas ?
    ... so as such differs to gazebos ?
    2002 Defender 130 DC HCPU. : Own the road...Any road
    ‘1981 R-Rvr Classic 2-Dr 3.5L V8... The Greatest Rover.
    ‘1975 Series3 88 PUP... Simply Classic...
    ‘2017 Metalian Mini ... A Home from Home
  15. #53
    Mar 2011
    Walker Bay
    Thanked: 1033
    Yes but sidewalls are available and then metal expandable poles provide support for the sidewalls across the top.
    They are quick to erect, light weight and pack smaller than gazebo's. I have both.
    Bundu essentially designed to provide shade not rain cover.
    We use our gazebo for longer stays, to cook in when it rains and for overall rain/wind protection.
  16. #54
    Jan 2014
    Thanked: 477
    I still want to add eyelids between the 2 side poles. Then I can use the cross poles, for the side awning, and tighten the top over the cross poles with a rope. This together with putting up the side poles, closer to the vehicle, at a angle to create a bigger slope should do the trick in stopping/minimising pooling of water.
  17. #55
    B-gowrie Randburg
    Thanked: 205
    Thanks Paul ... so I have a senior gazebo and now plan is to have 8 eyelets (3 per side = 6 plus 2 end ones for the 2 taller poles )put in to use those spiked support poles ...
    so will be much quicker to put up
    and take down than for the original gazebo frame pole system ...
  18. #56
    Mar 2011
    Walker Bay
    Thanked: 1033
    Don't forget the pics please!
  19. #57
    Gauteng
    Thanked: 938
    Mounted on the side of my DC and pitched with only one side-wall.
  20. #58
    Jan 2014
    Thanked: 477
    Quote Originally Posted by AntonN View Post
    So if you can now add an eyelet to pull the top over the cross pole for the side you should get rid of the sag in the roof and stop the water from running down the inside of the side wall.
  21. #59
    Gauteng
    Thanked: 938
    Quote Originally Posted by Daniek View Post
    My plan was to take a Sidewall pole which already has two eye ends.
    The centre tent pole(s) has a protrusion same as the poles for the sidewall. Since the sidewall poles are telescopic, one can put an eye end on one centre pole and the other end on the opposing centre pole and "stretch" the sag in the centre....
    I have not tried it because I am not looking forward to fiddle with this. To be honest, I am actually considering selling the Bundu Canopy for an awning. Just trying to explain my idea makes me tired....
    There is also the tennis ball on a tent pole trick, but that takes up real-estate....
  22. #60
    Jan 2014
    Thanked: 477
    Yes, I also thought about a pole in the centre. But then you will need a short pole on the vehicle side, like on caravan tents. As you say, then it starts to take away some of the easy setting up.
