Results 1 to 11 of 11
    Lonehill
    Thanked: 35
    Default GC Wk2 3.6 Decat
    Morning all
    Cats are dying in my GC, there’s a strong Sulphur smell out of the exhausts.
    Anyone removed the cats and if so comments on performance, fuel consumption, noise, etc
    Then who can be trusted in the northern parts of JHB to remove the cats and do the necessary to stop the ECU throwing a wobble after they’ve been removed.
    Thanks in advance!!
    D
    2014 Jeep Grand Cherokee Limited 3.6 Pentastar
    1967 MGB GT
    Fishhoek
    Thanked: 168
    Default Re: GC Wk2 3.6 Decat
    talking from having this done on my 5.7 hemi, a competent tuner using the HP Tuner and software should be able to delete the 2nd set of O2 sensors via the ECU after removing the cats. Also should be able to do all sorts of other useful ECU adjustments like fan activation temp.
    2010 Eagle Head 5.7 hemi
    Thanked: 249
    What's your odometer reading, why are your cats destroyed? Should I expect the same on my Wrangler that has 160k on?
    Grand Cherokee 5.7L V8
    Alfa MiTo Quadrifoglio Verde - she's a beauty!
    JKU Rubicon Pentastar (sold )
    JKU CRD (sold)
    XJ 4liter (sold )
    Thanked: 71
    My MIL comes on about ever 3000km with faulty cats. I clear it and it's fine for a couple of months then fault comes on again. My wk2 3.6 has 150k km.
    So very interested to know how to do this successfully.
    Is there any advantage to removing the cats?
    2018 Toyota Fortuner 2.4 4x4 auto
    Metalian Maxi
    2014 Jeep Cherokee 3,2 Limited AWD A/T (swambo)
    2012 Jeep Grand Cherokee 3.6 Overland (sold)
    2011 Fortuner 3 D4D 4x4 (sold)
    Lonehill
    Thanked: 35
    Car has done 110k km, but most of it in traffic running kids around 20-30kms a day and then 100km trips on the freeway Friday and Sunday, or at least I think that’s why...
    D
    1967 MGB GT
    Lonehill
    Thanked: 35
    Quote Originally Posted by Bartman71 View Post
    Apparently improved performance and fuel consumption or so I’ve heard...
    D
    1967 MGB GT
    Thanked: 71
    Any update on this @hercules_za?
    Metalian Maxi
    Thanked: 33
    My cats in my 2011 5.7 Hemi are doing the same.
    I would like to do a cat back exhaust and delete the cats
    2011 Jeep Grand Cherokee Overland 5.7
    Previous Jeeps:
    2012 JKU Rubicon 3.6 V6 on 37's with Synergy 5" Lift Kit with Fox 2.0 Factory Racing Shocks with Synergy Adjustable Control Arms
    2010 JKU Rubicon 3.8 V6 on 35's with Synergy 4" Lift Kit with Fox 2.0 Factory Racing Shocks
    2008 JKU Sahara 2.8 CRD 6sp Man on 33's with Full Traction 3"
    Lonehill
    Thanked: 35
    Nope, did some more investigation and the car will tell you when they’re knackered. Will throw a message on the OSD something along the lines of
    The car has 4 cats, so you only remove the rearmost cat on each exhaust.
    I was told that Powerflow in Midrand were probably the best to cut them out, but you need to get Cat Foolers/Mini Cats installed afterwards and the codes cleared.
    Mini Cats around R600 each and probably about R2k for the exhaust work, so a relatively cheap exercise compared to replacing the cats at about R30k.
    D
    1967 MGB GT
    Thanked: 71
    Quote Originally Posted by hercules_za View Post
    Thanks.... Good to know
    Metalian Maxi
    Fishhoek
    Thanked: 168
    Quote Originally Posted by rickJK View Post
    rick JK read my post#2 above.
  12. The Following User Says Thank You to skala For This Useful Post:
