Installing a amplifier
Results 1 to 3 of 3
    Nov 2018
    malmesbury
    Default Installing a amplifier
    Hi guys
    I am new here and not sure if this is the correct platform to post. I need advice please .
    I want to install an amplifier in my Steed 5 , but I do not have a clue how to get the wire through from the cab to the battery . Can I use another power cable to connect to the amp's power cable ?
    Kind regards
    Shawn
    Mar 2012
    heidelberg g
    Thanked: 22
    Default Re: Installing a amplifier
    rather not.....
    find a way to fit a new cable through which has the correct fuse in line, close to teh battery.
    we dont want it on fire with tears running down your cheeks!!!
    Mar 2017
    louis trichardt
    Thanked: 24
    From inside the bonnet side you look for the place where the vehicles harness goes through. Get hold of some steel wire if possible but any tipe of hard wire will work then you gently push it through the rubber molding to the inside. Tape the amps wires to the steel wire and pull it back and proceed from there
    DIESEL POWER
