4JB1T - Possible Overheating
Results 1 to 13 of 13
    Thanked: 17
    Default 4JB1T - Overheating / repair / diagnosis?
    Hi guys,
    Need some help here please. FIL seems to have cooked the engine of his Isuzu. What I have so far is that he had a leaking waterpump and somewhere over the past weekend, he had managed to overheat the engine. He checked the water in the radiator prior to leaving the house, but didn't check the expansion bottle. Drove the bakkie hard as he was running a bit late and on way home it seems something has popped. Pulled off and had the bakkie towed home and hasn't started it since.
    Any ideas on where we can start looking to assess possible damage? He is a pensioner, so replacement engine should be the very last option (prior to complete rebuild) oh and because of said pensioner status, him and I will DIY the repair as much as possible (will check in on the forum for advice on the DIY part as well )
    T.I.A.
    André
    André
    1998 Isuzu Frontier 280DT 4x4 - Resurrected
    Platkar (Hers) Ford Figo 1.4TDCi
    Sep 2012
    johannersburg
    Thanked: 29
    Default Re: 4JB1T - Overheating / repair / diagnosis?
    Quote Originally Posted by KB280DT View Post
    Hi guys,
    T.I.A.
    André
    id say pull off head and bottom end and see main bearing and evrything does the engine swing or is it ceased?
    ISUZU KB300LX DMAX mine / 1.4tdci with software exhaust and intercooler and watermeth injection /dad-kb300 dteq kb5 4x4 /uncle kb300 4x2 dteq kb5 /step dad. Kb6 kb300 4x4 auto all double cabs
    Thanked: 17
    I’ll check tomorrow afternoon if it swings. He can’t seem to remember if he tried starting it again or not.
    If it starts and the engine runs, I suppose I can assume he got lucky and that damage might be limited to the head and head gasket?
    André
    Jul 2016
    Pringle Bay
    Thanked: 764
    Default Re: 4JB1T - Possible Overheating
    Dont forget on diesels if they overheat rings take a beating, sorry
    Audi A6 Avant Quattro V6 tdi ( Sold )
    VW Touareg V6 tdi ( sadly written off )
    2 x Toyota Celica GT4 Gen 6 (Sold) sadly missed
    2 x Toyota Celica Gen. 5 ( Sold ) not missed as much as the above.
    Sep 2017
    Richardsbay
    Thanked: 80
    Sorry to hear about the troubles.
    Been there done that.
    A compression test on all 4 cylinders is a good place to start.
    I'd do that before trying to start it.
    If you do start it, check for excessive breathing/smoking at the oil filler cap.
    Hoping for the best.
    Thanked: 17
    Thanks guys. Busy having the battery charged up and then have a look Saturday morning. If the engine is shot, he’ll probably sell it as is.
    André
    Thanked: 17
    UPDATE:
    F.I.L. decided to tow it to the mechanic. Opened up the engine and somehow the one piston sleeve dropped out of the block / in to the block.
    He's sold it as is.
    André
    Thanked: 9697
    He sold the bakkie? When an import engine is around R25k?
    Thanked: 17
    Yup, sold it
    André
    Thanked: 9697
    Yup, sold it
    hard thing to say, but what a CHOP
    now he has no bakkie? and was probably paid peanuts?
    I hope I don't get that stupid as I get older.
    Thanked: 17
    More a case of finances in this instance. When you’re a pensioner, 25k can be a lot of money
    André
    Thanked: 9697
    And no family members can get a R25k personal loan? Oh well..........
    Thanked: 17
    Want to cry some more?
    The cause was a leaking water pump which I offered to replace numerous times
    André
