Grand Cherokee WK suddenly won't start. Is my battery kaput?
Results 1 to 20 of 39
    Sep 2015
    Home
    Thanked: 527
    Default WK suddenly won't start. Is my battery kaput?
    Tried to start the Jeep, starter turned over a few times, although not particularly enthusiastically. Now just clicks when you try. Also got a "service park assist" message, then "service 4wd system". Interior LED lights flickered a few times before coming on properly.
    Reading 12.44V across the battery terminals. Is it likely dead? Anyone with a healthy WK able to provide a voltage reading for comparison? Don't want to replace battery unnecessarily.
  2. The Following User Says Thank You to HeavyG For This Useful Post:
  3. #2
    Jul 2008
    Constantia Kloof
    Thanked: 1013
    Default Re: WK suddenly won't start. Is my battery kaput?
    Quote Originally Posted by HeavyG View Post
    Are the terminals tighened correctly?
    It sounds like a loose connection. If the terminals are tightly attached, then check the earth strap as well as the thick cable running from the battery to the starter motor.
    Brandt Theunissen
    2019 Mahindra S6 Pik Up S/C 4x4
    2007 Mercedes Benz ML500 5.5
    1968 VW Beetle 2276
    Sep 2015
    Home
    Thanked: 527
    Terminals are tight and spotless. Will check the rest later. Started flawlessly last might, a bit odd that it's struggling now just a few hours later.
    Sep 2015
    Home
    Thanked: 527
    Loaned a charger from my neighbour, had it on about an hour and it went up to 12.88V and that was enough for a flawless start, so I pulled out of the garage so long and left it parked on the driveway.
    Will see a bit later what happens, check if there's any current flowing while it's off, measure voltage with alternator running, etc.
    Other suggestions also welcomed at this stage.
    Thanked: 13623
    Matches?
    Thanked: 362
    Sounds like it could very likely be batter, I would suggest you swing by your local Battery Center and have them test the battery. All the warning lights and strange phenomena is consistent with a battery problem.
  8. The Following User Says Thank You to Commander For This Useful Post:
    Sep 2015
    Home
    Thanked: 527
    Matches?
    Let's keep that one on the back burner for a while longer.......
    Sep 2015
    Home
    Thanked: 527
    Yeah, going to call around for pricing first and have it tested to make sure.
    Jul 2009
    West Beach - Bloubergstrand
    Thanked: 121
    This sounds like battery, My JK did the same thing.
    I noticed it coming for about 2 months where my Jeep would turn, but as you say... not enthusiastically.
    One day I wanted to start it up, it turned then the relay started clicking and my lights came up.
    I put it on charge and nothing helped.
    I had a deep cycle battery in my boat, put it in my Jeep to test, Jeep started right up.
    SO I took my wifes car to Super Quick and bought a new battery for R850, and its has been good since.
    2008 - Jeep Wrangler Rubicon JKU
  12. The Following User Says Thank You to JKUR For This Useful Post:
  13. #10
    Sep 2015
    Home
    Thanked: 527
    Battery tested OK, so not sure what to make of it. Still possible it's borderline and just barely on the right side of the "GOOD/BAD" line... will see how it behaves.
  14. #11
    Thanked: 191
    Sounds like the dreaded "dead cell"...
    Had same thing with just about every car i've owned and its always been the same thing...
    "I am a hypocrite but i try not to be..."
  15. #12
    Thanked: 26
    Hi HeavyG
    The four-wheel drive service message on the WK is often the battery. My brother bought a WK where that message came up but the battery still had enough to start the engine. The Jeep spent days in the stealer's workshop and they could not figure it out. A few days later the battery dies, it was replaced on no more message.
    I recently had issues in determining if my deep cycle battery is dead. Had it tested at a few places and got different responses, tested it at home, charged using different chargers etc etc. At the end of the day I am just gonna replace the battery.
  16. #13
    Sep 2015
    Home
    Thanked: 527
    Yes despite the test I'm 95% certain its about to give up on me. If it happens again tomorrow morning I think I might as well replace it.
  17. #14
    Apr 2011
    Sandton
    Thanked: 211
    Sure it's battery (relay clicking no start) and for peace of mind and not getting stranded somewhere prolly best just to replace battery.
    '06 TJ Wranger | 4.0L Auto| 4.5" Lift | 35" Copper STT | 15" MT Classic II Black | 4.88 Gears
  18. #15
    Glenvista
    Thanked: 8
    Had the same symptoms on my WK a while ago and it turned out to be a dead cell on the battery.
    Basil Peetz
    2014 Jeep Grand Cherokee 3.6 Overland
    2013 Triumph Tiger 800 XC
  19. #16
    Sep 2015
    Home
    Thanked: 527
    Dead this morning. Time for replacement.
  20. #17
    Sep 2015
    Home
    Thanked: 527
    Sorted, R1,600.
  21. #18
    Cape Town - RSA
    Thanked: 352
    I had same issue, I think it does not allow it to start if certain voltage from the battery is available.
    Ex - 2005 Cherokee CRD
  22. #19
    Apr 2011
    Sandton
    Thanked: 211
    Sorted, R1,600.
    Good stuff
  23. #20
    Norway
    Thanked: 354
    Good thing you didn't torch it
    Mitsubishi ASX AWD top spec. - stock
    Land Rover Defender 90 2.8i - OME lift on 33" muds, bullbar, racks, freeflow.
    Jeep Grand Cherokee 3.0 CRD WK - Mud terain 32's, Spacers, Lift kit, GDE Tune.
    Jeep Wrangler Rubicon 3.8 JK - Mud terain tyres. Aftermarket mufflers.
    Jeep Cherokee
    3.7 Sport KK - 40mm EFS lift, Mud terrain tyres, Spacers, skids.
    Jeep Cherokee 3.7 Extreme Sport KJ - 40mm spacer lift
    Suzuki Jimny ジムニ - EFS lift, ARB bullbar, Custom Maniac Rocksliders, Mud tyres, etc etc.
