Removing a solar panel from caravan roof. - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 56 of 56
    May 2016
    Beyerspark
    Thanked: 220
    Default Re: Removing a solar panel from caravan roof.
    Well done. At least it was only glued down on the edges.
    Drive: Nissan Hardbody DC TD 16V 2007
    Camp with: Jurgens Xplorer 2010 with a couple of mods
  2. #42
    Mar 2007
    Wow! The suspense! Glad it came off
  3. #43
    Centurion, Pretoria, SA
    Thanked: 238
    I just cannot get over how that stuff held right up to the last cm.
    Right now I see a prototype protective cover being developed. What say yee - a windproof padded canvas cover with zips or some other design?
    SOMETIMES I WAKE UP GRUMPY,
  4. #44
    Thanked: 238
    I went back and read the article again and see now they are referring to semi flexible panels. Oh well, maybe I will make a protective cover anyway.
  5. #45
    Jul 2009
    Simon's Town
    Thanked: 216
    Yes, I was not keen to hijack your thread but TRONís comment did the trick.
    Malcolm
    2015 Pajero 3.2 LWB
    Bushwakka Sundowner No. 31
  6. #46
    Wartburg
    Thanked: 758
    Fishing line and piano wire were mentioned. If one can't get piano wire, get fishing trace wire, which is easy to get - works very well.
  7. The Following User Says Thank You to mikeml For This Useful Post:
  8. #47
    Thanked: 238
    7 years of sun, rain and pollution had turned that "stuff" into a hard dry compound. Was also in a recess making more difficult. Was on my own, the wire trick works better with two people. Sharp thin kitchen utility knife, getting right up to it so as to get power behind knife, working small little sections at a time. Once off, cleaning the roof and panel I can see how hard that stuff got. Now to fit the new panels.
    Thanks again every one.
  9. #48
    May 2014
    Welkom
    Thanked: 11
    Glue them
    Groot avontuur begin met ń idee, ń braai en ń lemonadetjie.
  10. #49
    May 2016
    Beyerspark
    Thanked: 220
    Quote Originally Posted by bosklong1 View Post
    Glue them
    I heard Sikaflex is the only way to go.
  11. #50
    Thanked: 1744
    Quote Originally Posted by Gerhardvr26 View Post
    yeah me too, highly recommend it.
    BMW R1200R
  12. #51
    Mar 2009
    Florida
    Thanked: 519
    And preferably the grey product. 😇
  13. #52
    May 2014
    Welkom
    Thanked: 11
    That and tea
  14. #53
    Thanked: 238
    That and tea
    I was waiting for that.
  15. #54
    Witsand
    Thanked: 106
    Eish, me too. I have just installed a solar panel on the Bundutop and looked at Sikaflex. After reading up on the stuff I decided against it as it would probably cost me a new roof if I have to remove it. Went with rivets and VHB tape.
    Do not, DO NOT use Sikaflex for anything you may wish to remove again. It is an excellent sealing product and the reason it is 4 times the price of normal hardware type silicone is that it is 4 times stronger and lasts forever! Great for sealing joints and rivets though, and for that PERMANENT job!
  16. #55
    Apr 2015
    Western Australia
    This stuff apparently works on Sikaflex removal,try your local marine chandler https://www.amazon.com/DeBond-MF12-Marine-Formula-Aerosol/dp/B07CSYP3LH
  17. The Following 2 Users Say Thank You to eddyoz For This Useful Post:
  18. #56
    Oct 2007
    Wichenford, United Kingdom
    Thanked: 44
    I had a Satfi satellite dome removed, but could not remove the feet. I am not sure if the Debond would work in these circumstances as oneen of the feet covers about 20 square centimetres and there are 4 of them?
    2012 Jeep Grand Cherokee Overland Summit CRD chased by a 2018 Buccaneer Cruiser twin axle caravan.
