Results 1 to 12 of 12
Thread: Aircon.
    Apr 2008
    Welkom
    Thanked: 83
    Default Aircon.
    So the guys that fixed my Defender's air-con stuffed up the nut that holds the vents/duct in place, so it is now lose.This is the bolt above the gear lever.How can I make another plan to get the duct fastened as there is no way of getting in there?
    Land Rover Defender 2.8i 110 CSW.
    Nov 2011
    Langebaanweg
    Thanked: 1709
    Default Re: Aircon.
    I haven't worked on that part of the Defender dash. I can only recommend that you either remove the whole lower part and if not possible go in from the top.
    Sorry not much help.
    I also have to go in there to figure out why the left vents blow stronger than the driver's vents.
    Thanked: 16
    Default Re: Aircon.
    Is the bolt stripped. I know its a long one that screws into the the origional dash. One can actually drop the bottom piece being carefull to manoeuvre the aircon pipes through the rubber bung in the firewall on the left hand side. If the thread that the long bolt screws into is striped, one could maybe drill it out and put a rivnut in there
    Charles
    Defender TDI 110 CSW
    Lift, Long Range Tanks, Dual Battery's, A few Dents and loads of FUN!
    Don't Regret Enjoying Life!!
    Cape Town Southern Suburbs
    Thanked: 1502
    Default Re: Aircon.
    Or maybe try and extra large self tapper/steel sheet self drilling screw to replace the stripped bolt, that's if the bolt is 6mm or smaller.
    Apr 2008
    Welkom
    Thanked: 83
    Default Re: Aircon.
    Thanks guys.
    cape Town - 0624206806
    Thanked: 522
    Default Re: Aircon.
    Rivnut
  7. The Following User Says Thank You to GaryFrank For This Useful Post:
    Dec 2013
    Ramsgate Kzn
    Thanked: 134
    Default Re: Aircon.
    Quote Originally Posted by Jacque W View Post
    Hi Jacque ..
    what do you mean stuffed up the nut ?..I think a bolt fits in there
    the 3/8 ratchet with appropriate socket size ( rachetsmaller than the half inch ) fits in there ..
    you can remove the bolt and use a bigger washer to hold it together ...
    hope it works ..
    Apr 2008
    Welkom
    Thanked: 83
    Default Re: Aircon.
    Quote Originally Posted by guy4ever View Post
    Hi Jacque ..what do you mean stuffed up the nut ?..I think a bolt fits in there the 3/8 ratchet with appropriate socket size ( rachetsmaller than the half inch ) fits in there ..you can remove the bolt and use a bigger washer to hold it together ...hope it works ..
    The nut is missing and I cannot get in here at all - all enclosed.
    Dec 2013
    Ramsgate Kzn
    Thanked: 134
    Default Re: Aircon.
    Its not a nut its a bolt .. you need to use a small socket ratchet to get in there cause a normal socket wont fit
    Lusaka
    Default Re: Aircon.
    The original LR set up is to have a rivnut in the dash and a long M6 Screw (or nut) that goes through the A/C unit and into the rivnut. If they failed to refit the screw you could get another one and fit it yourself - try M6 x 1.25 x 60mm. If you want to inspect the area you can unscrew the black screws on the side of the whole unit (near the doors on both sides) and drop the unit a few centimetres. It will be resting on the A/C pipes but is usually fine. Then you can see if the rivnut is present or turning so you can decide to fit another one and put in a new screw. Its usually best to fit that screw back first before the screws by the doors.
    Hope that helps.
  12. The Following User Says Thank You to nickhodgson For This Useful Post:
  13. #11
    Oct 2018
    Pinelands
    Thanked: 31
    Default Re: Aircon.
    Hope the OP doesn't mind me asking here as an aside, but I was looking at my AC unit this weekend and found that the AC pipe manifold where it enters the Firewall has no protection of any sorts surrounding it. Can one buy something that fits around this to protect it from chafing on the firewall ?
  14. #12
    Lusaka
    Default Re: Aircon.
    If you have the same model of A/C as the OP then you need JQS100230 which is the grommet that protects the A/C pipes and supports the back of the evaporator.
