Jimny replacement battery
Results 1 to 15 of 15
    Thanked: 95
    Default Jimny replacement battery
    Could of sworn I created this thread already
    There was a thread discussing a slightly larger battery for the Jimny, anyone know the model number, or which thread it was?
    My battery died today.
    Sep 2013
    Thanked: 46
    Default Re: Jimny replacement battery
    Quote Originally Posted by xrapidx View Post
    Was there any rust involved?
    2009 Suzuki Jimny - EFS, roofrack, muds, etc
    2012 Suzuki Jimny - Sold May 2014
    2009 M/B Sprinter 315 P/v : for work
    2008 Honda F-RV 1.8v-tec AT: for family
    1968 Toyota Corona 1.5 : for ever
    Sep 2013
    Thanked: 46
    I have a 631C
    Doubt if you'll be able to fit a larger one. The 631C fill all the space in mine.
  4. The Following User Says Thank You to PetriB For This Useful Post:
    Thanked: 22
    For around R600 you can get an additional battery plate for the front and get an auxiliary battery. I'd much rather go that way. Even 35ah is not a lot. At 50% decharging you are looking at 17ah, my thermo cooler will kill that in 7 hours.
    Thanked: 95
    Quote Originally Posted by PetriB View Post
    You joke, I should actually check what was used to wire the spots, make sure its coast friendly
    Thanked: 95
    Quote Originally Posted by StefanDB View Post
    How much would wiring it up coast though? Wouldn't you need some sort of intellegent monitoring system?
    Jan 2007
    Thanked: 314
    I doubt any manufacturer would sell him one. He'll let battery acid leak onto it, leave it for 2 years until it rusts through, then claim that it is a poor product.
    Vic
    Thanked: 95
    Quote Originally Posted by saxj View Post
    Only poor quality manufacturers would have batteries that leak so easily from the get go, unless maybe the batteries also aren't meant for the coast?
    Thanked: 22
    The National Luna intelligent solenoid is also around R 700 without the battery monitor attachment which you don't really need. The power that you draw will only be from the aux battery.
  11. The Following User Says Thank You to StefanDB For This Useful Post:
    Thanked: 95
    Thanks - I'll do a bit of reading on it and see if I can get it done DIY.
  13. #11
    Oct 2015
    Waverley
    Thanked: 14
    2010 Suzuki Jimny _Charcoal _Led interior lights _DIY Parcel shelf _DIY Plywood loading board
    _Campmaster loading bars _DIY Awning_DIY Spotlight brackets with LED Lights _Rocksliders_ 50 mm suspension lift with Gabriel Safari HDP Shocks
    _Lots of fun
    On the list:
    _Xenon kit
    _Aux Battery + Dual charging system
    _Undies
    _Replacement bumper
  14. #12
    Thanked: 95
    Thanks - going to visit battery center on Friday, vehicle has started fine, and immediately everytime this week, but don't want to take the chance - I'll keep the existing battery as a backup.
  15. #13
    Thanked: 95
    Went to battery center - battery is fine, and alternator is charging, but battery is flat... went to Midas and confirmed same. I drive for at least 2 hours....so wtf.
    (I went to Battery Center after driving around for about an hour)
  16. #14
    Nov 2017
    Gauteng
    Thanked: 21
    My battery also just died overnight , if I jump start it , it will run , but dies as soon as I put the a/c on , alternator is charging correctly. 14,2 with load , 14,5 without .
    Never seen a car die once it's running with only a bad battery , a bad alternator sure , unless the std alternators charge rate is piss poor ?
    2011 Suzuki Jimny . 40mm zombie offroad lift , 215/75/15 tyres, 50mm powerflow .
    Disco 2 Td5, 3 inch lift, straight pipe, remap, egr delete, cdl mod, 32/11.5/15 all terrains. ( Sold )
    1985 Suzuki Sj410 , 970cc of stock Japanese power , 245/75/15 muddies , 2 inch lift . ( Sold )
    2016 Harley iron 883 , lowered , tank lift , wire tuck , fender delete, flipped mirrors , straight pipes . ( Sold )
    Various Volvo company cars over the last 6 years .
    2001 Polo Playa Millenium , stock besides 75hp nitrous shot. ( Sold )
    1987 Caddy , 2.1 16v Abf , 44mm throttles , 288 billet cams , 11.5 :1 compression. ( Sold )
    1981 Mk1 Golf , 1900cc , weber 38 dgas , 298 cam , tnt branch , 11.5 : 1 compression . ( Sold )
  17. #15
    krugersdorp
    Thanked: 317
    battery short on inside.disconnect it completely.happen to me on SX4.
    could not even jump start with battery inside a circuit.
