4.5 Patrol Fuelling woes
Results 1 to 7 of 7
    Jan 2009
    Default 4.5 Patrol Fuelling woes
    Installed long range tank through LA Sport in PE. Big mistake! Serious fuelling problems and erratic running. Took it to SAC. Still not sorted.
    Any ideas?
    Bothasig
    Thanked: 14
    Call their head office in Pta and demand to speak to Lionel (the owner). I'm sure he'll get them sorted.
    '02 Patrol 3.0Di GL
    Did your Patrol not come with a second or sub tank as standard equipment.
    If so, where did you find space for a further tank?
    If not, what year model is it?
    I am asking because with a 135L capacity (90L main, 45L sub), the current 4.8 Patrol only has a range of about 600km, leaving a small safety margin, under ideal onroad conditions.
    I have not enquired yet, but I simply do not see space for a further tank.
    It would be nice if one could improve the range to about 800 to a 1000km.
    Let us know how and where the tank was fitted, and what the problems are, maybe a solution pops up.
    2007 Nissan Patrol 4.8 Tiptronic GRX
    TJM XGS 1" suspension
    TJM Snorkel
    BFG AT'S
    Melvill & Moon Seatcovers
    Dual Battery System
    40L Engel
    Garmap Montana 600
    Tyredog
    Venter Botswana Special
    Jul 2008
    Default Patrol longrange tank
    Hi Wynvat, as jy ander tenk soek vir jou patrol - Northern offroad in Strijdom Park, hulle maak 'n 140l ene wat die 95 liter een vervang, gee jou dan so 900km range afhangende van hoe jy ry.
    cheers
    Rian
    Hallo Rian
    Dankie, dit is goeie nuus.
    Ek het hulle (Northern Offroad) nou net gebel.
    Soos jy se, hulle vervang die 90L tenk met een van 140L, en jy behou die subtenk van 45L. Dus het jy 185L.
    Koste is net onder die R6k, alles ingesluit.
    Klink vir my na 'n kapitale plan, is daar enige lede wat al hierdie ombouing laat doen het?
    Ek dink ek gaan dit laat doen voor ek weer 'n trip doen.
    TJM Snorkel
    BFG AT'S
    Dual Battery System
    40L Engel
    Garmap Montana 600
    Tyredog
    Jul 2007
    Pretoria (PvR)
    Ek het met een van LA Sport se manne gepraat oor hierdie selfde ombouing.
    Hy se dat hulle BAIE probleme daarmee kry, omdat hulle jou ou tenk afhaal en dan al sy parte (flout vir die meter ens) moet oorbou op die nuwe tenk.
    Daarna kla die kliente oor die fuelgauge wat nie reg lees nie, of brandstof wat uitlek, of brandstof reuke ens.
    Ek is bang daarvoor....
    Enige iemand wat dit dalk gedoen het, en dalk eerstehandse ondervinding
    hiermee het
    Albert Gravett
    Isuzu KB6 3.0 D-Teq D/C 4x4 Auto
    ORRA Call Sign B66
    Jul 2008
    Hi ek het myne laat doen nadat 'n vriend van my ook syne laat doen het. Myne is nou al 7 maande op en kan gladnie kla nie. Jy don so 300km dan le jou naald op 3/4 en daarna volg hy presies dieselfde roete as voor die tenk gefit is. Ek vind net dat mens nie die laaste 5 liter kan gebruik nie want dan begin sy sluk sluk. Dan gooi ek so 134/5 liter in. Ek het nog geen issues opgemerk van petrol reuke of lekke nie.
    Die manne by Northern Ofroad gee puik diens!! Ek kan hulle beslis aanbeveel.
    Rian
