Cost to heighten a wall
Results 1 to 20 of 34
    Jul 2017
    Sandton
    Thanked: 144
    Default Cost to heighten a wall
    What would an educated thumbsuck be to make a double brick wall higher? Its the old red face brick type. Raise it by let's say 1m or 1,5m. Looking for a per meter price. It's around a very old factory so doesn't have to look nice, just want to stop prying eyes looking in.
    2018 VW Amarok V6 Auto 4Motion
    2011 VW Golf GTI DSG
    2007 VW Golf GTI
    2003 VW Citi Life
    Thanked: 10262
    Default Re: Cost to heighten a wall
    Around 110 bricks for a 1m H by 1m L double thickness wall extension.
    Wall Type: double brick non load bearing
    Length (in metres): 1
    Height (in metres): 1
    WALL (METERS SQUARED) : 1
    BRICKS REQUIRED : 110
    SAND: 0.08 cubic metres
    CEMENT: 0.36 bags
    If you tell us how long the wall is, it can be more accurate.
  3. The Following 2 Users Say Thank You to jelo For This Useful Post:
    Jul 2017
    Sandton
    Thanked: 144
    Thanks Jelo
    Would want to raise about 150 to 200m of the wall.
    2007 VW Golf GTI
    2003 VW Citi Life
    Thanked: 10262
    WALL (METERS SQUARED) : 150
    BRICKS REQUIRED : 16500
    SAND: 12 cubic metres
    CEMENT: 54 bags
    Now you can phone around and get quotes.
  6. The Following User Says Thank You to jelo For This Useful Post:
    Jul 2017
    Sandton
    Thanked: 144
    CEMENT: 54 bags
    Thanks.
    Wasn't there a builder on here somewhere?
    2007 VW Golf GTI
    2003 VW Citi Life
    Dec 2016
    Thanked: 90
    just a note - you may need to have the height assessed as a 230 wall has limits in height i.t.o SANS 10400. May need stabilising piers and small bases. Also the jointing regime needs thought. Are you going to have plans done and submitted? Are you going to fund cash? All has impact and can attract cost. My 2c
  9. The Following User Says Thank You to ed rouillard For This Useful Post:
  10. #7
    Thanked: 2322
    Quote Originally Posted by Ooba View Post
    Thanks.
    Jip. But he built high walls around himself
  11. #8
    Jul 2017
    Sandton
    Thanked: 144
    Quote Originally Posted by ed rouillard View Post
    Will get plans done if needed. The wall is already about 4m high.
    I am now actually thinking of using IBR sheeting to "raise the wall". Its literally to give another meter or so of privacy.
    As stated previously it doesn't matter at all how it looks, the property is in a heavy industrial area with an informal settlement next door.
    2007 VW Golf GTI
    2003 VW Citi Life
  12. #9
    May 2015
    Jhb North
    Thanked: 89
    Ditto what Ed said,
    See attached extract from the national building regs ( SANS 10400 table 17) - your wall is probably already close to it's max height (depending on shape, piers, etc.) - even if it isn't yet, I would guess that there's not much chance that you can add 1 to 1.5 m without it exceeding the allowable heights.
  13. #10
    Jul 2013
    Thanked: 377
    Smile Re: Cost to heighten a wall
    If you use IBR, you'll be contributing to someone next door's new shack!
    09 Kyron, the Korean Snail.
    NO Meeow!
    Blanked EGR.
    Thermo Electric Cooling fan.
  14. #11
    Thanked: 10262
    For the price of a wall extension, what about a 1.5m cattle grade electrical fence on top of the wall?
  15. #12
    Bethlehem
    Thanked: 118
    Alternatively, maybe look and see if possible to add a Pre-cast wall on top of the existing wall?
    Christo Davids
    Land Cruiser 105 4500 EFI
    Hilux 2.8GD6 Extracab 4x4
  16. #13
    Thanked: 10262
    Quote Originally Posted by Christo Davids View Post
    a fit 12 year old can break a precast slab
  17. #14
    Greenstone Hill
    Thanked: 120
    CEMENT: 54 bags
    Spot on, and get double wall brick force as well - for every 3rd row you add
    Mark Trollope
    Prado 120 V6, Fortuner V6, Hilux 2.7, Cruiser 80 EFi, Cruiser 75, Lexus RX350, Jaguar JAKI4
  18. #15
    Bethlehem
    Thanked: 118
    Yes, but the intention is to do this on an existing 4m high wall, so increase privacy? Surely the Pre-CAst will do the job and be more cost effective than bricks?
    Need to check whether foundation will hold the heightened wall, etc... Better than IBR in my opinion...
    Christo Davids
  19. #16
    Thanked: 10262
    when he says privacy I think he means ACCESS CONTROL
    "the property is in a heavy industrial area with an informal settlement next door" "The wall is already about 4m high."
    A 4m wall cannot be looked over easily. It takes quite a bit of effort.
  20. #17
    Mar 2015
    Thanked: 76
    Depends on the topography of the area, the settlement could be on a higher elevation allowing prying eyes in.
    Ford Ranger 3.2 Auto 4x4 XLT
    Paj DiD SWB Auto
    E92 335i 430kw at the wheels!
    VW G6 GTi DSG
  21. #18
    Jul 2017
    Sandton
    Thanked: 144
    Quote Originally Posted by Kish2604 View Post
    Spot on. It's not for security purposes at all, just privacy. There is plenty security on site.
    2007 VW Golf GTI
    2003 VW Citi Life
  22. #19
    Thanked: 723
    You are going to need an engineers assessment and sign off on the extensions if it's even possible, so I would do that before even getting quotes.
  23. #20
    Oct 2012
    Lambert's Bay
    Thanked: 102
    Go ask Donald Trump!
