Saw on FB !! Disco burned out. - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 56 of 56
  1. #41
    Mar 2015
    New Germany
    Thanked: 421
    Default Re: Saw on FB !! Disco burned out.
    dry grass getting wrapped round prop shaft, or UJ yokes and it gets wrapped very very tight, the friction then courses heat and then fire, once the fire starts with grease or any underside insulation it gets bigger
    if you driving in dry areas with grass or seeds always check under car every few hours, this is very common
    1995 300TDi Defender with VGT Turbo
  2. #42
    Grotto Bay
    Default Re: Saw on FB !! DIsco 4 burned out.
    Sad!!
  3. #43
    Thanked: 761
    I would like to get the story from Kaspaas.
    One of the stupid mistakes in life is to underestimate peoples level of stupidity!
  4. #44
    Wellington
    Thanked: 438
    I will ask him to post an update. He doesnt log in here much anymore
    Some car, some bike and two legs
  5. The Following User Says Thank You to hcs For This Useful Post:
  6. #45
    Thanked: 985
    I followed the FB to and fro.
    Their son indicated that the fire was caused by grass/ seeds caught under the Disco.
    A horrible loss for anyone.
    The couple we physically unscathed and the caravan slightly dirtier than before.
    I have seen a few MV Fires and the spread speed is pretty incredible at times.
    My advice - remove yourself and any personal effects/ valuables asap.
    If you have a quality fire extinguisher you can then try extinguish the fire but NEVER put life at risk.
    Stay Safe
    Disco-Deon
    This morning I woke up,
    Making today a great day.
    Nerdy, 2011 Honda Jazz, 1500 Exc
  7. #46
    Wellington
    Thanked: 7
    Jip, was my ouers en die laaste been van hulle trip naby aan Mabua.
    Warm, droe gras, stadig gery, hoe middelmannetjie etc.
    Het gereeld gras sade onder die engine plate verwyder, maar hoeveel is genoeg.
    Hulle het rook geruik, gestop en probeer blus, onmoontlik om met die brandblussertjie in die hoekies in te kom want dit smeul orals.
    Het later met sand en water probeer gooi, maar toe die vuur eers by die petrol toevoer kom was dit verby.
    Die raad wat hulle gee, moenie probeer red en jou lewe in gevaar stel nie.
    die plate onder die engine is dalk goed vir rotse maar dalk n resep vir vure om te begin?
    Hulle is veilig terug met n onbeskryflike ervaring.
    Niks meer nie en niks minder nie, mbt feite.
    Bel my gerus indien julle vra het, aangesien ek nie elke dag hier loer nie.
    082 nege 0 twee een 2 drie 3
    Groete
    2007 Discovery 3 Td V6
    110 Defender 300tdi
    KTM 950 Adventure
  8. The Following 6 Users Say Thank You to Kaspaas For This Useful Post:
  9. #47
    Thanked: 761
    Quote Originally Posted by Kaspaas View Post
    Groete
    Net baie dankbaar almal is veilig, en die inligting is gedeel sodat ons almal kan leer daaruit!
  10. #48
    Delmas
    Thanked: 622
    Groete
    Sterkte vir jou ouers. Ons kon danksy 7 GROOT brandblussers en omtrent al ons water ons voertuig blus. Daar gesien dit gebeur in sekondes. Gebeur in CKGR in 2009. Dit het lank by my gespook.
    Les geleer daaruit dat jy altyd jou belangrikste goed binne grypafstand moet hou. Ons het 2 dae gelap en plak en kon uitry. Maar sjoe! Dit was byna.
    Elize
    en ry saam met SarelF in
    VW AMAROK MET BLINKGATCAMPER:
    My Platkar:- Peugeot 208
    Kyk gerus by www.blinkgatproducts.com
    Vir enige aluminium produkte,canopy's, campers kontak gerus
    Sarel 0828209413
  11. #49
    Thanked: 217
    Ek het in 2013 die rook/ smeul reuk ervaar in my Prado V6 op die kaplyn aan die Weste kant van CKgr. Nie aangename ervaring nie maar gelukkig nie gebrand nie. Het lank gestop en skoongemaak en gereeld.
    Maar dis amper onmoontlik om orals skoon te maak...... dis n gestoei om orals in te kom en die plate is groot probleem. My senuwees was op.
    Francois
  12. #50
    Wellington
    Thanked: 438
    Groete
    Thanks Calle.
    Daai bo is nogal n goeie vraag. Haal die plate dalk af, maar sal dit n verskil maak? Jy expose dalk net meer hitte, warm olie ens aan droe gras.
    Nogal n point to ponder
  13. #51
    Thanked: 86
    Quote Originally Posted by hcs View Post
    Thanks Calle.
    Plate afhaal, 'n goeie idee.
    Olie op gras net 'n Land Rover probleem...
    Groete,
    Suid-Wes
    2006 Defender 110 Td5
  14. #52
    Mar 2011
    I have seen so many of these burnt out bodies or seen actual reports on them, I'm sure the problem exceeds the recent Ford problem. Yet there has been no comment from the manufacturer.... strange
    Generators are a passing fad
  15. #53
    Thanked: 199
    Quote Originally Posted by Heinz4x4 View Post
    It's not a manufacturer fault. It is a known risk when driving through long grass and precautions need to be taken. It is also not tied to a brand. Prado's are as much at risk as Land Rovers possibly even more so. The reality id if you take your vehicle into this kind of environment you need to be aware of the risk and take the precautions. Sometimes even old experienced hands get caught out as the grass may be longer, drier or whatever variation exists.
    We as users need to accept responsibility for ourselves and not always need to read a label telling us the obvious.
    2012 Disco 4 SDV6 HSE - Amazingly competent
    2014 Crosspolo 1.2TSI - General runabout
    2011 KTM 990 Adventure - The classic can do bike
    Sadly sold: 2004 Disco 2 V8 - My beach cottage no more
    Finally retired: 2006 Volvo XC70 - Swambo's platkar that could
  16. The Following 3 Users Say Thank You to DiscoMatt For This Useful Post:
  17. #54
    Gaborone
    Thanked: 959
    Which manufacturer are you thinking of ..
    The burnt out vehicles can be Pajeros, Landies, and Toyotas (seen some Prado) so who would reply ...
    Kalahari Safari
    Nissan Patrol GU TB45
    E39 - 540i for the open roads
  18. #55
    Thanked: 761
  19. #56
    Thanked: 10057
    Quote Originally Posted by Luka View Post
    paid subscribed content only
  20. The Following User Says Thank You to jelo For This Useful Post:
