Rumbling wheel bearing but no play - Page 2
Results 21 to 22 of 22
    Thanked: 1233
    Default Re: Rumbling wheel bearing but no play
    Liquid Nitrogen or Dry ice is the best way to shrink bearings. Liquid nitrogen around -190deg and dry ice -100deg We fitted bushes and bearings this way with diameters of up to 700mm and buses 1.2m . I doubt if the -12deg of a deep freezer will be enough.
    Heating the hub you will you be able to fit a bearing in there that is at room temp. You need to check hub temp with Tempilstik not to disturb metallurgic composition of hub metal while applying heat. Make sure you act very quick heat transfer between hub and bearing can be surprising fast. not nice to have it stuck halfway down the bore. After fitment cool down as quickly as possible to prevent damage to bearing seals and grease.
    Dec 2011
    Thanked: 1760
    I've done this method three times already with success.
    Hub gets heated to about 300 celsius
    My thermal camera says bearing is at -40 celsius
    Bearing drops in (only just) and then I add water to cool everything and keep grease from overheating.
