Results 1 to 20 of 21
    Wonderboom Pretoria
    Thanked: 69
    Default Suzuki Samurai SJ413 Transfer Case urgently needed! Please!!
    I'm desperately looking for a sound Suzuki Samurai SJ413 (preferably out of a SJ70 or wide track model) transfer case, to replace my Coily's (SJ80) transfer case!
    Please!!!
    Real 4x4's don't have
    curved windscreens!!
    Jeep TJ 4l Sahara 33'
    Suzuki SJ 80 "Jeepie"
    + 2 classic roadsters
    some dangerous toys
    Jun 2016
    JHB
    Thanked: 103
    Default Re: Suzuki Samurai SJ413 Transfer Case urgently needed! Please!!
    Join this FB group and ask the guys on there.
    https://www.facebook.com/groups/198455870662455/
  3. The Following User Says Thank You to Wooky For This Useful Post:
    Thanked: 248
    Quote Originally Posted by Pablo View Post
    Please!!!
    Contact Chris from Pretoria Cote 88 in Pta. West, Suzuki expert, could have a spare one for you in the shop.
    (012) 327-0902 , (012) 327-0903
    2014 Nissan Navara 2.5 4x2
    1995 Nissan Sani 3.0 V6 4x4
  5. The Following User Says Thank You to staalwol For This Useful Post:
    Wonderboom Pretoria
    Thanked: 69
    Is daar niemand op die forum wat hul SJ413 "transfer case" met 'n SJ410 s'n vervang het en die SJ413 s'n aan my wil verkoop nie?
    Asseblief? Die Samurai is my "daily drive" en sy ketting gly al hoe meer gereeld!
    some dangerous toys
    Thanked: 17964
    Quote Originally Posted by staalwol View Post
    Listen to this advice.
    Jakes Louw
    Wonderboom Pretoria
    Thanked: 69
    Ek was alreeds by Chris gewees, voordat ek die forum se hulp gevra het en hy het juis aanbeveel dat ek 'n SJ413 "transfer case" soek, dan sal hy dit vir my insit
    some dangerous toys
    Jun 2016
    JHB
    Thanked: 103
    Wouldn't a Jimny transfer case fit?
    Wonderboom Pretoria
    Thanked: 69
    As I understand, the first Jimnys had lever control (kort kierie) transfer cases and are interchangeable (if not exactly the same as) with the Coily's. But not the later models with electronic selection. Any old Jimny cases available?
    some dangerous toys
    Jun 2016
    JHB
    Thanked: 103
    forgot about the lack of lever....
    Jan 2007
    Thanked: 364
    There will be very few of those about. All of the ones brought to SA by Suzuki were push button.
    Vic
  13. #11
    Wonderboom Pretoria
    Thanked: 69
    No SJ413 transfer cases lying around?
    some dangerous toys
  14. #12
    Dec 2013
    Paarl
    Thanked: 506
    Not at my place, no.
  15. #13
    Wonderboom Pretoria
    Thanked: 69
    some dangerous toys
  16. #14
    Dec 2010
    Durbanville, Cape Town
    Thanked: 21
    Remove transfer case, take to gearbox place to replace chain. Re-fit transfer case, drive a few hundred thousand more km?
  17. #15
    Wonderboom Pretoria
    Thanked: 69
    Quote Originally Posted by nickza View Post
    Chain alone, without gears, bearings, seals and other components that might be damaged, is R.6 200-00 and the original chain didn't last 100 000km! The gear-driven SJ413 transfer cases are stronger, with better gear ratios and more re-gearing possibilities, although noisier!
    some dangerous toys
  18. #16
    Thanked: 17964
    Jakes Louw
  19. #17
    Thanked: 17964
    100,000kms in Pretoria is about 4 years of driving.
    That is a divorced transfer case: surely a small Jeep NV will work or the Nissan Safari transfer case?
    Jakes Louw
  20. #18
    Wonderboom Pretoria
    Thanked: 69
    Both are SJ410 Transfer cases. Gear ratios won't work for the Coily, well maybe on 35" tires!
    I'm sure there are a lot of transfer cases that can be used with a lot of modifications, but the SJ413 cases from 1990 to 1995 are the perfect fit!
    some dangerous toys
  21. #19
    Sep 2016
    Thanked: 36
    Any success with TC?
    Iíve got a 1996 coily, consider fitting a 410 TC or crawler box. The SJ413 TC is still in excellent condition.
    Will confirm if / when it become available, uír welcome to test drive SJ before removing TC.
    Still looking for TC and some gears.
    Theuns
    07to7nin7nin455
  22. #20
    Sep 2016
    Thanked: 36
    Daai coily TCís is baie skaars!
