Solar panel voltage monitor
Results 1 to 2 of 2
    Thanked: 15
    Default Solar panel voltage monitor
    I hope someone can help.
    I would like to know if one can get a voltage monitor that can sense when a panel outputs more than say 26V (adjustable) to switch off the grid and run on solar. This is to disconnect solar also when very cloudy and during the 16h30-08h30 period in summer. Currently using a timer for the 16h30 to 08h30 period. My invertor is no fancy unit.
    Also where can I buy it?
    Thanks.
    Jan 2018
    Thanked: 24
    Default Re: Solar panel voltage monitor
    this maybe
    https://solaradvice.co.za/product/re...ammable-relay/
    otherwise try Communica for a voltage relay, they have all sorts of gadgets.
  3. The Following User Says Thank You to Learnercamper For This Useful Post:
