Drilling or Welding onto Trailer A-frame
Results 1 to 5 of 5
    Thanked: 353
    Default Drilling or Welding onto Trailer A-frame
    I would like to install additional corner jacks to the front of my Trailvan. These will need to mount onto the A-frame. Likewise I want to move the jockey wheel from the cross-member in the a-frame to the a-frame itself.
    Are there any concerns I need to have in drilling holes to mount such onto the a-frame? Can it cause weaknesses in the frame which will come to haunt me? Is welding better?
    2007 Touareg 3.0 V6 TDI (Facelift, Air, Rear Diff Lock, Rear Mounted Spare)
    2008 Audi A4 B8 2.0 TDI (Multitronic)
    2009 KTM 990 Adventure (Weekend Fun)
    2012 Imagine Trailvan 4-Sleeper
    * consumption needs to be seen in the context that the vehicle is towing an Imagine Trailvan 30% of the time
    Thanked: 6332
    Default Re: Drilling or Welding onto Trailer A-frame
    If you do drill, you'd need to install a crush tube anyway which needs welding........
    I'd weld onto the outside using inert gas (TIG or MIG) and not DC or AC arc.
    Thanked: 353
    Thnx., can you elaborate on the crush tube, - not following...
    Trying to do similar to this...
    A frame is u channel.
    Thanked: 6332
    Quote Originally Posted by Kortgat View Post
    If it is U-channel (lipped or not, doesn't matter) then I'd just use a spreader plate on the back. The last thing you want is having torn or elongated mount holes on the U-channel.
    Crush tubes are for closed square tube/closed rails so that the bolt doesn't squash the tube when you tighten everything and apply force to the mount.
    Thanked: 353
    Aaah ok, got it. Thnx
