Tata Xenon 2.2 cambelt
Results 1 to 2 of 2
    Sep 2014
    Default Tata Xenon 2.2 cambelt
    My truck’s cambelt broke. Put pins in the right holes for the timing ie the flywheel, the dieselpump, and the camshaft, and replaced the belt. I did not replace the radiator. The engine rotates but does not start. I also neglected to mark the position of the balancer.
    Any advice please.
    1972 Ford Escort 1600L-Swopped Mom for BMW below
    1978 BMW 518-Sold
    1981 BMW 518-Sold
    1985 Mazda 323 SLE-Sold
    1992 Mazda B2200-Sold
    1990 Audi 500-Sold
    1998 Ford Mondeo 2.0-Sold
    2001 Toyota Condor 2.4 RV-Sold
    2006 Mazda 3-Sold
    2005 Ssangyong Musso Sports-Sold
    2009 Tata Xenon 2.2 DLE DC-Still Current
    Thanked: 194
    Default Re: Tata Xenon 2.2 cambelt
    Does it have any compression.
    If it has compression. The camshaft can be one resolution out. Remove belt. Keep all the other pins in. Remove pin from camshaft. Turn it a full resolution. Refit belt. Turn engine by hand to make sure the pistons don't hit the valves. Try and start it again.
    If not then it might've bent valves if it is an interference motor. Don't know those engines.
    2005 Land Rover Discovery 3 V8 (Will allways end up with an V8)
    1967 Land Rover Series 2A 3.5 V8 (The Green Machine)
    196? Land Rover Series 2 V8 100" (The Coiler)
    2007 Subaru Forester XT 2.5T (The Daily)
    Ex.
    1996 Land Rover Discovery 1 Tdi
    1997 Land Rover Discovery 1 V8
    2001 Land Rover Discovery 2 V8
    2006 Land Rover Discovery 3 TDV6
    2007 Land Rover Freelander 2 TD4
