Which CTEK to use
Results 1 to 4 of 4
    Jan 2008
    Default Which CTEK to use
    Hi all
    Please I need some advise I have a Disco 4 with duel battery system. At the moment when not in use I use my CTEK XS 3600 to keep the battery charged. I had 3 2 have backed up so only have 1 left. Which CTEK should I buy to keep the Batteries Charged?
    Thanks very much
    Hyundia Terracan 2.9 CRD Sold.
    Swambo's 2013 Landy Disco4 SDV6 SE
    New Hyundia I20 Auto run around
    2016 Jurgens Xplorer
    Thanked: 106
    Default Re: Which CTEK to use
    This one seems to be highly recommended on the forum... Midas PSA008 2/8 Amp DC Smart Battery Charger
    Forum link: https://www.4x4community.co.za/forum...43#post3415243
    Midas link: https://www.midas.co.za/pebble.asp?relid=1739&t=75
    Mar 2011
    Walker Bay
    Thanked: 704
    I have two Midas - originally recommended by Fluffy -
    There is a non-digital model and a digital charger which is more expensive.
    As far as I can see both perform the same functions.
    I have the cheaper version.
    Used for years - no problems.
    Wartburg.
    Thanked: 241
    I have got that exact same charger, Midas PSA008 2/8 Amp DC Smart Battery Charger
    And two Victron chargers, a 10 amp and a 15 amp.
    When I use my two Vicrton chargers they float a battery a 13.2 Volts, the Midas charger floats the battery at 12.5 Volts
    Why is that?
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
  5. The Following User Says Thank You to Chris8d For This Useful Post:
