Pajero Sport vs Gen4 Pajero Exceed
Results 1 to 15 of 15
    Default Pajero Sport vs Gen4 Pajero Exceed
    Hi guys
    After long contemplation and consideration on what route to take I finally decided to trade my 2011 Pajero Sport 3.2DiD for a 2015 Pajero 3.2DiD Exceed LWB with RDL. I do quite a lot of grade 4-5 4x4'ing and have read endless articles on offroad capabilities between the two vehicles.
    I know as far as luxury, comfort, space and driving pleasure goes the Gen 4 is the better buy. I also have twins on the way so I believe the Gen 4 have more space. Just hope I can still do my weekend trails with as much ease and effortlessness as with the Paj Sport.
    I would just look at raising the body a bit with either a spacer lift or proper suspension lift.
    Would love to hear from you Gen 4 Pajero 4x4 trail enthusiasts.
    Thanked: 303
    Default Re: Pajero Sport vs Gen4 Pajero Exceed
    Congrats.Thats a good upgrade.I cant comment on 4x4 ability of the sport as i cant recall ever driving with one or seen one on a proper trail.The gen4 can do the bits but not sure about grade5 especially without damage.For the rest the gen4 is great and when you get to know how to use the traction control properly it is capable
  3. The Following User Says Thank You to Mr.G For This Useful Post:
    swakopmund
    Thanked: 1145
    Quite impressed if you regularly do grade 4-5 4×4ing with either of that vehicles !
    Quote Originally Posted by Bartho View Post
    Yes have done some nail-biting, butt-clenching obstacles with the Paj Sport.
    Jan 2016
    Thanked: 575
    Quote Originally Posted by Wynandsc View Post
    Then you DEFINITELY need a lift on the Gen4! Good luck.
    2001 Gen 3 Pajero swb 3.2 Di-D
    Nov 2006
    Thanked: 312
    I know its early days but please remember to give us some feedback about your adventures.
    Dont forget the Mitsubishi section under Vehicle and Technical Chat.
  8. The Following 2 Users Say Thank You to Damdan For This Useful Post:
    Richardsbay, KZN
    Thanked: 2759
    I am no trail entusiast but suspect the Sport will be more nimble when it comes to the tight stuff. Drove behind one today and it doesn't seem as wide as a Pajero.
    Walker Evans, Photographer
    Lonehill, JHB
    Thanked: 682
    A grade 5 obstacle means you are 99% guaranteed of vehicle damage and a grade 4 is where you may need both rear and front lockers.
    I suspect your trails are probably Grade 3 at best.
    Having said that, the Sport has a solid rear axle and less of a saggy “backside” rear bumper so from a clearance perspective it will certainly perform better off-road when it comes to the rough stuff.
    A Gen4 needs a 50mm suspension to make it more capable (you can’t do a body lift because it’s a monocoque) because in standard guise it’s very low to the ground.
    Let us know how you find it after your first trail please.
    2014 Pajero 3.2DiD SWB
    Thanked: 134
    35mm difference.
    2015 Pajero Sport 4x4
    1996 3.5v6 Pajero (For Sale)
    Carpe Diem Scrotum
    Give a man a beer, waste an hour. Teach a man to brew, and waste a lifetime!
    swakopmund
    Thanked: 1145
    Would be interesting to test them back to back . Anyone up for a dunetrip ?
  13. #11
    Richardsbay, KZN
    Thanked: 2759
    Quote Originally Posted by SimonB View Post
    35mm difference.
    That's not much Simon, it appears to be more but the Pajero is more square which will make it seem much wider I guess.
  14. #12
    Nov 2006
    Thanked: 312
    And it stands higher arse in the air so it looks "thin".
  15. #13
    Thanked: 134
    Quote Originally Posted by Damdan View Post
    Snort.
    “Put your arse in the air dear. It makes you look thin. “
    Carpe Diem Scrotum
  16. #14
    Mar 2016
    Thanked: 1344
    Wow... So Carnage Canyon will be a breeze for you?
    Respect...
  17. #15
    Richardsbay, KZN
    Thanked: 2759
    Indeed, that might also be why it looks more compact.
