Dual Battery and Isolator
Results 1 to 2 of 2
    Jul 2017
    Default Dual Battery and Isolator
    Hi Guys
    New at this so bare with me. I looked through the threads for an answer and didnt find anything.
    I am using the Ctek Dual DS charger in my car. I have one aux battery.
    Do i need to be able to isolate the aux battery from the system when the car is stationary?
    From the basics I remember with a soledoid system this is require to prevent the batteries draining into each other. But not sure about the CTEK Dual D system. Or is it built in?
    If the answer is yes i need it, your advice on how and where appreciated.
    Okahandja, Windhoek
    Thanked: 857
    Default Re: Dual Battery and Isolator
    Ctek dual does isolate the aux battery when stationery by itself.
    Johan Kriel
  3. The Following User Says Thank You to JLK For This Useful Post:
