Is this it? - Page 99
Page 99 of 105 FirstFirst ... 49 74 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 LastLast
Results 1,961 to 1,980 of 2094
Thread: Is this it?
  1. #1961
    Default Re: Is this it?
    My D2 developed air leak in one of the rear bags, 15 minutes later it had a good shot of gorilla snot in it (those Tyre sealant stuff) and was working well for long after that.
    Fixing my trailers broken steel suspension cost me the best part of our traveling day, and the repair only lasted one week.
    It's not always as bad as it looks, but I guess one has to upskill your roadside repair knowledge and tools as tech advance in vehicles.
  2. #1962
    Oct 2007
    Uitenhage
    I have no problem with calling them more unreliable than steel springs, as there are so many more components to airbags which can go wrong.
    This is exactly what I'm saying. So we agree then. More likely to fail. Not gauranteed or even likely to fail
    Looks like you've had bad luck with your airbags. What exactly went wrong in each case, and was it DIY fixable?
    Ride height sensors, both, on two different occasions.
    Air bag leaks, replaced both when one failed.
    Compressor failure on two vehicles, the D3 due to off-road damage, the D2 due to age.
    I could jipo my way to a workshop on all the failures.
    I don't think that it was bad luck though, according to all the indys I've spoken to, failures from less than 10 years are to be expected.
    2004 Land Rover Discovery 2 Td5 ES
  3. #1963
    The Windy City
    Something that I also believe gave the airbags in the D2 a bad rep was the fact that they were never replaced, if I recall correctly those airbags had to be replaced after 5 years, and they were hardly expensive as well, but I am not sure how many D2's ever had this done, so now you have a lot of vehicles on the road with ageing airbags long overdue for replacement, but when one of those bags fail the market blaims the entire air suspension setup.
  4. #1964
    Oct 2007
    Uitenhage
    What some of the industry has to say:
    "For tractors, air ride suspension became the standard many years ago on over-the road applications, while vocational vehicles often use leaf spring suspension because of their greater durability and capacity" Rob Braswell, technical director of American Trucking Association's Technology & Maintenance Council.
    "little maintenance is required for leaf spring trailers during their first six or seven years. Over 10 years, maintenance costs are 900$ for air ride versus $240 for leaf springs." Xtra Lease.
    "The company tests found that while leaf spring suspension while leaf springs suspensions can last the life of the trailer, air ride suspension are more likely to require replacement and more prone to failure." Steve Duley, vice president of Schneider.
    And surprisingly perhaps one opinion on ride quality:
    Leaf springs actually provided a better ride quality in most circumstances. ... air rides are better when trailers are empty..." Steve Duley.
  5. #1965
    Oct 2007
    Uitenhage
    I agree. The airbag leaks. It is ignored. Then the compressor overheats trying to keep the bag inflated, replacing the bag would have saved the compressor.
    I replaced mine with Arnott Springs which have a 10 year guarantee.
    Air suspension does normally give you warning before it fails completely.
    It's failure which a steel spring can't have though.
  6. #1966
    Quote Originally Posted by Fontuin View Post
    I had a 1984 One Ten V8. I sold it around 2010. Strange fact that in 26 years the coil spring hadn't broken yet. Very weird. I must just be lucky.
  7. #1967
    Hillcrest, Malaysia
    Interesting point.
    Air suspension almost always gives you warning symptoms.
    Steel suspension seldom does.
    And for people using it InDaBush, a little knowledge, and some simple tools and spares makes it almost fool proof.
    Steel on the other hand, a broken leaf spring or cracked/snapped attachment point, eish.
    And believe it or not, the friendly smooth nature of air bag operation seriously reduces the stress and load on accompanying suspension elements.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  8. #1968
    Hillcrest, Malaysia
    Thats why Land Rover used coils instead of leafs.
    ZS5KAD
    3 V8's
  9. #1969
    MTUNZINI
    And those D2 airbags were vulnerable, not as in D3 onwards where they were protected inside a thin aluminium flask canister against dirt, grime and stones and the rubber sheive underneath
    Koos Best
    Land Rover Discovery3 TDV6 S.
  10. #1970
    Bethlehem
    Quote Originally Posted by franscoies View Post
    Ek like daai onboard Pompie...............
    Of COURSE I have a Bad Habit. I take Tea at Three (Mick Jagger)
  11. #1971
    Apr 2014
    Krugersdorp
    Ek ook! Die “onboard compressor” is ook nogal cool!
    Nissan Navara d23 (Leatherman)
    Jeep Cherokee 3.2 (Swambo’s sportscar/ mommy taxi)
  12. #1972
    Feb 2016
  13. #1973
    Sep 2010
    Deep south - mink, manure & marijuana
    And the estimated price in SA is ??
    Sam
    ZS1SAM
    V5/ZS1SAM
  14. #1974
    Mar 2013
    Australia price for the high output diesel SE version works out at R950 000.
    Pieter Greyling
    ONE LIFE, LIVE IT!
    ORRA: Z85
    -Land Rover Defender 110 Td5
    -BMW G650 xChallenge
  15. #1975
    Nairobi
    Quote Originally Posted by pjf110 View Post
    High output diesel... Is that the SDV8 in FFRR and RRS?
  16. #1976
    Mar 2013
    Quote Originally Posted by byaru1 View Post
    No nothing that special. The 2.0 engine delivers either 147kw or 177kw dependent on tune.
    BUT imho the low output would be the better option for something like a defender.
    Pieter Greyling
    ONE LIFE, LIVE IT!
    ORRA: Z85
  17. #1977
    Doing Time in CKGR
    Exactly the same testing that the D4 and no doubt the D5 went through ... I have an almost identical vid clip of the D4 doing these tests
    VW Amarok V6 4Motion Highline Plus
    Defender 130 HCPU TD5
    SOLD - D4 SDV6 HSE
  18. #1978
    Nairobi
    Well.. why? A little extra power never killed anyone.
  19. #1979
    Feb 2016
    assuming the same internals and it's just a map, more power = less longevity
    besides, you want low-end torque and ability to cruise at 120kmh, not necessarily at 160kmh.
  20. #1980
    Nairobi
    I thought the Amarok owners already disproved this school of thought?
    It's just 20% more power that you probably will use like 10% of the time you own the car. If it were to last you 50 years, it will instead last 40. Or if it were to last you 20 years, it will do 18 instead. Numbers aside, I only see this approach by manufacturers as a marketing and product differentiation gimmick. I hardly see longevity of the car being in question here.
    How about those very few times you want to overtake 5 trucks at once :-P
