Is this it? - Page 169
Page 169 of 196 FirstFirst ... 69 119 144 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 194 ... LastLast
Results 3,361 to 3,380 of 3903
Thread: Is this it?
  1. #3361
    Oct 2017
    Rustenburg
    Thanked: 3928
    Default Re: Is this it?
    Quote Originally Posted by pjf110 View Post
    The rim sizes are a pity but its worth remembering that the new defender runs on larger diameter tyres overall. So in 18” and even 19” it has a respectable sidewall length.
    Current Hilux/Fortuner runs 265/65R17 thus 172mm high sidewall
    Defender runs 255/70R18 thus 179mm (more than a standard 4x4 bakkie)
    Or
    255/65R19 for the powerful models at 166mm sidewall height. Thats a mere 4% difference in sidewall height to the typical 4x4 bakkie.
    D4s ran 255/55R19, thats 10% less than the defender. So don’t expect the same tyre trouble that the discos had.
    This ^ makes sense, and explains things nicely. Thanks
    Andrew van Staden
  2. The Following User Says Thank You to Hedgehog For This Useful Post:
  3. #3362
    Thanked: 87
    I take it that what you are saying is that you use the same wheel and increase the tyre size? If you increase the tyre size as you indicate, then, what about the gearing? Could you still lug around all the weight you need to?
    He mentioned a 33" tyre. A 33" tyre is a 33" tyre regardless of the size of the rim.... By deault all the new Defenders come with a 32" tyre regardless of whether you choose 18, 19, 20 or 22" rim size. So yes, changing to a 33" will affect the gearing a bit, but it's only a 1" difference in size, it's not going to make a huge difference with the modern engines that the Defender has
  4. #3363
    Oct 2017
    Rustenburg
    Thanked: 3928
    Quote Originally Posted by byaru1 View Post
    Is it about the rim size or Sidewall height? @DevonEllett sums it well.
    On a Ranger Rover?
    Andrew van Staden
  5. #3364
    May 2010
    Greenstone
    Thanked: 392
    My 110DC has 285/75r16s which I stand corrected have a sidewall height of 213mm which fits easily with a 2inch lift.
    How much sidewall could you get onto the new Defender if you lift it before it eats its own fender? Big rims mean nothing to me, you want tyre.
    PS when Jeep upgrades the Wranglers (Their offroad icon) they made sure there was ample space for guys to put bigger tyres on and for guys to adapt it.
    Discovery Sport 2.0i D
    Defender 90 LE Puma 2.2TDCI
    Defender 110 DC Td5 (life partners)
    Discovery 1 200 Tdi Auto
  6. #3365
    Oct 2017
    Rustenburg
    Thanked: 3928
    Quote Originally Posted by DevonEllett View Post
    I did not see where this is said? And yes, 1" will not make much difference, my bad. I was talking about the 34/5" in the next post without referencing them.
    Andrew van Staden
  7. #3366
    Thanked: 87
    From what I can find, these are the standard sizes available:
    255/70R18 (32”)
    255/65R19 (32”)
    255/60R20 (32”)
    275/45R22 (32”)
  8. The Following User Says Thank You to DevonEllett For This Useful Post:
  9. #3367
    Oct 2012
    Thanked: 145
    Quote Originally Posted by Byron View Post
    Guys have already fitted 33" tyres with only 1" inch lift. So should be able to fit 275/70/R18s giving you a perfectly respectable sidewall of 193mm
    2015 Land Rover Defender 110 (Sadly sold )
    2020 Land Rover Defender 110 (On order )
    Website: www.africanrover.co.za
    Instagram: african_rover
    Twitter: african_rover
  10. #3368
    Jan 2014
    Heliport
    Thanked: 292
    I don't think anyone is debating those points with you but that sounds like the full fat Range Rover design brief, only thing missing is most luxurious.
    If it is a Defender replacement that has been developed and has played catch up in design, then why is there no pick up or double cab?
    I'll tell you why because that Defender is dead and the new one is just a name to cash in on the heritage. Do I blame them for doing it? Definitely not because it is a business and they out to make money like every other business.
    I would buy it as well as an everyday car but I am fortunate to have a proper 90 and 110 as well which will always be the Defender I know.
    Defender lost the workhorse game many moons back
    Using Tapatalk
  11. #3369
    Oct 2017
    Rustenburg
    Thanked: 3928
    255/70R18 (32”)
    255/65R19 (32”)
    255/60R20 (32”)
    275/45R22 (32”)
    Am I correct in saying that the 18" (255/70R18) are the steelies exclusively"
    Andrew van Staden
  12. #3370
    Jan 2014
    Heliport
    Thanked: 292
    You have just proven that you actually know nothing.
    Think not , had a Defender , still has a Wrangler . Toyota on the farm .
    Using Tapatalk
  13. #3371
    Oct 2012
    Thanked: 145
    No - can get 18" alloys. Unfortunately on the P400 the smallest wheel you can get is 19" due to the size of the brakes fitted. However someone in Dubai has already fitted 18" after-market wheels - although they did have to shave down the brakes a tad to get to to fit.
  14. The Following User Says Thank You to PaulMark For This Useful Post:
  15. #3372
    Thanked: 15077
    Quote Originally Posted by cor View Post
    So you say Wrangler JK and JL don't have coil springs?
    Jakes Louw
  16. #3373
    Oct 2017
    Rustenburg
    Thanked: 3928
    He says they are not overlanders
    Andrew van Staden
  17. #3374
    Oct 2012
    Thanked: 145
    Just got back from my test drive of a D240 in SE spec. Unfortunately I didn't get to spend a lot of time with it as they had test drives booked throughout the day and each car has to be sanitised between drives. First impressions are overwhelmingly positive and I cant wait for mine to get here. Contrary to what a lot of people have said the car feels huge - especially from the drivers seat.
    A few points I picked up which may be of interest.
    • The rear sets can be moved forward to increase space in the boot
    • The vehicle I drove was fitted with Goodyear Wrangler Duratracs. The standard offroad tyre is Goodyear Adventures but if you prefer Duratracs these can be fitted by the dealer. Road noise was not noticeable with the Duratracs so I think I will be getting them assuming LR can supply at a reasonable price...
    • The built in compressor looks very slick but for R11k they can keep it. Also wont work with a drawer system as the drawers will block access
    • Dealer tells me that of their first delivery all except a few of the lowest spec S versions are already sold
    • Apparently none of the first batch were petrol
  18. The Following 3 Users Say Thank You to PaulMark For This Useful Post:
  19. #3375
    Nairobi
    Thanked: 155
    I wonder why.
    What is an overlander by his definition.
  20. The Following User Says Thank You to byaru1 For This Useful Post:
  21. #3376
    Tzaneen
    Thanked: 315
    Quote Originally Posted by PaulMark View Post
    Duratracs are same price or cheaper than AdventureShould not be extra cost if you chose to have Duratracs fitted.
    2012 RR TDV8 4.4
    2006 TDV6 SE A/T(Sold)
    2008 FL2 TD4 SE A/T
    1968 Renault 8 Gordini
  22. #3377
    Thanked: 15077
    No, he said the Defender coil springs made it more comfortable.
    Jakes Louw
  23. #3378
    Feb 2016
    Thanked: 955
    Sjoe, quite a few people slagging a vehicle they either have no intention of buying or cannot afford to buy
    As the French say, les chiens aboient, la caravane passe...
  24. #3379
    Thanked: 15077
    And as the Afrikaans say, n vark Bly n vark Al dra dit lipstiffie
    Jakes Louw
  25. #3380
    May 2010
    Greenstone
    Thanked: 392
    Are you going to trade your Puma 90 in on one?
