Is this it? - Page 14
Page 14 of 105 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 39 64 ... LastLast
Results 261 to 280 of 2094
Thread: Is this it?
  1. #261
    Gauteng
    Default Re: Is this it?
    All we can agree on is that the guys waiting for the New Defender to be something like the Wrangler JL or Toyota LC70 are going to be terribly disappointed.
    Take the D3 and D4 and massage that box shape a bit and then add all the gizmos from the current line-up and you'll see what will be launched.
    Pretty much summed it up
    https://youtu.be/UWjR4d9pBys
    2003 LR Discovery 2 GS V8
    2013 LR Discovery SDV6 SE (SWAMBO)
    2014 BMW X5M
  2. #262
    Default Re: Any update on the new Defender
    Still valid!Click image for larger version.
    '89 LR 110 V8
  3. #263
    good one, Mike
  4. #264
    I am curious.
    I have never owned a Defender.
    What will the things be all the naysayers is going to miss in the new Defender?
  5. #265
    Nov 2011
    Langebaanweg
    Character and soul.
    Something most vehicles don't have.
    84' Land Rover Defender 110 V8 4-speed Hardtop (Meisiekind) Sold after 12 years of fun and hard work
  6. #266
    Oct 2007
    Uitenhage
    I am curious.
    Durability. Simplicity. The ability to take abuse. The ability to be customized for specific applications. Off the showroom floor ability, no need for expensive aftermarket bumpers, bigger wheels, after market suspension, under body protection... whatever.
    You could take a stock standard Defender, load a ton on to it, and take a turn off of a poor road on to no road with little chance of damaging it even in the most difficult terrain.
    If you haven't owned a Defender and/or used it for what it was built. You wouldn't understand.
    2004 Land Rover Discovery 2 Td5 ES
  7. #267
    Character and soul.
    In other words an old vehicle? Since a new vehicle can never have that.
    Its like my 2002 Bugeye STi. Nothing will ever have its Character and soul (for me), but time moves on and even if the new STi might be better in every sense, for me it wont be a substitute.
  8. #268
    Quote Originally Posted by Fontuin View Post
    Clearly not, even though my Disco can do many of those (in comfort) as Kingsley has illustrated numerous times.
  9. #269
    Nov 2011
    Langebaanweg
    That's where you are wrong. A brand new Defender has that.
    Although the new one might be awesome, it will lack it.
    Very few people will take a new Discovery and treat it or modify it like was done to the Defender.
    Take for example rescue vehicles or fire fighting.
  10. #270
    Nov 2011
    Langebaanweg
    Here's a few examples.
ID:	515203   Click image for larger version.
ID:	515204   Click image for larger version.
  11. #271
    Oct 2007
    Uitenhage
    Spoken like someone who hasn't done in a Defender what a Defender was built for...
    The D4/5 makes a relatively strong case as a touring vehicle... pity it's about R 500 k over priced.
  12. #272
    May 2010
    Greenstone
    A D4 can do what a Defender does BUT for how long? It comes down to duty cycle.
    The Defender can take abuse for much longer than a D4. So if they can bring out the features of the D4 with the durability of a Defender I'm all for it. Tall order though.
    Time will tell.
    Ps and smaller rim to fit proper tyres, only issue I had with mine, it is a major drawback offroad.
    Discovery Sport 2.0i D
    Defender 90 LE Puma 2.2TDCI
    Defender 110 DC Td5 (life partners)
    Discovery 1 200 Tdi Auto
  13. #273
    Aug 2017
    Quote Originally Posted by Byron View Post
    Time will tell.
    As long as we donít confuse durability for reliability
  14. #274
    Fourways Gardens
    He asked a simple question, stop being so arrogant.
    Series III 88"
    Scout Nomad
  15. #275
    Oct 2007
    Uitenhage
    I am curious.
    Perhaps if I share my experience of the D3 with a number of Defenders it may be clearer.
    Here's what I found to be the primary problems compared to a Defender when I tried a D3.
    I speak under correction, but IIRC the D4 was quoted as having a ground clearance of 310 mm in off-road height.
    The Defender 250 mm, or something like that.
    So the D3 wins on ground clearance, right... well it's not that simple.
    The Defender's 250 mm is under the pumpkin of the diff which lifts with the wheel. The underside of the axle (which also lifts with the wheel) is at 330 mm and the bottom of the chassis at 350 mm.
    The engine, gearbox transfer case and other components are all tucked safely above the chassis, out of harms way at around 400 mm.
    You can slide a Defender on it's belly down a rock step without doing any damage to the body or other components (the Puma lost this ability to a degree because the handbrake drum was slightly lower than the chassis, although a pretty tough component). If you've cleared the obstacle with your axle, you can be sure that you won't be doing any damage, and if you hear a "clunk", you can be pretty sure it's just the cross member.
    With the D3 310 mm is pretty much what you have to work with because most of the bottom of the vehicle are more or less at that level with no chunky ladder frame chassis to protect it. It's one of the draw backs of a monocoque chassis. I lost a gearbox and a compressor because of this.
    The other major issue, as Byron has mentioned, is the large rims and low profile tyres. This is a drawback of chasing performance, because performance requires large brakes which require large brake discs and calipers which require large rims for them to be able to fit. Tyres are the most important part of your suspension. If you're doing sustained heavy off-roading in rocky terrain with low profile tyres, you're going to be replacing damaged rims and tyres.
    Steel bumpers are a very use full thing to have when driving through the veld to make short work of, termite mounds, small bused and trees... when necessary. I understand that legislation would probably have done away with this if the Defender were simply upgraded anyway.
    There were other issues as well but these are I think the types of things that wold distinguish the Defender from what is to come..
    These things won't be missed by the larger market and many Defender owners would probably never even have had to test their Defender's to it's limits but some people will miss these things that made the Defender a Defender.
    The D3 was a great vehicle to commute to the farm and back in, but once you're there and you're working, you want to be in a Defender.
    You will often find that farmers drive something as their daily drive but back in the shed, when work needs to be done, the Defender gets pulled out.
  16. #276
    Oct 2007
    Uitenhage
    I thought that oradba69 and I were having a very amicable conversation.
    No arrogance...
    I am curious.
  17. #277
    No arrogance...
    No sweat. We are still all Landy lovers and I cant wait for the new Defender in the hope it will be a good replacement for my Disco.
  18. #278
    Oct 2007
    Uitenhage
    Yes, I'm sure it will be a good replacement for your Disco.
    I'll probably be looking elsewhere if I ever need a replacement for my Defender.
  19. #279
    LR have given up the 'working vehicle' type market ( farming , firefighting, bush ambulance , national parks, armed forces, NGO etc) as you rightly pointed out.
    The luxury SUV market is obviously more profitable.
    However the Japanese haven't, especially Toyota and to a lesser extent Nissan.
    And for the 'working' applications mentioned above (farming etc) the 70 series LC in my opinion is a better product than the defender, more reliable, better value for money.
    That's why it had almost completely displaced the defenders for those applications long ago.
    What kept the old defender sales going was the leisure market, because of the 'adventure' image of the brand.
  20. #280
    Langs die rivier, op n berg
    Toyota het so 8 odd jaar terug gesÍ landbou is ongeveer 2% van hul bakkie verkope...
