Drilling Holes in Mild Steel
Results 1 to 17 of 17
    Gaborone, Botswana
    Thanked: 1195
    Default Drilling Holes in Mild Steel
    (Some useless stuff I did on Saturday)
    I had to drill some 12mm holes through 8mm flat bar.
    The Drill
    The Drill Bits
    I started off thinking to do a 6mm pilot hole and then the 12mm bit. 6mm went through without a problem. 12mm not. A quick sharpening of the 12mm bit and it went through. Second hole I did straight 12mm without the pilot hole. No problem. And so it went on for the next 40 by 8mm holes and lastly 10 by 24mm (3 x 8mm sandwiched). I did not have to sharpen the bit again.
    The Shavings (EDIT: Swarf) from the 12mm bit
    Job done.
    End of day.
    Drilling the 3 x 8mm sandwich. This was the second last one. Drill Bit still dong the job. Delo 400 as cutting fluid.
ID:	503055   Click image for larger version.
ID:	503056   Click image for larger version.
ID:	503057   Click image for larger version.
ID:	503058   Click image for larger version.
    Kobus
  2. The Following 2 Users Say Thank You to KobusDJ For This Useful Post:
    durban
    Thanked: 1112
    Default Re: Drilling Holes in Mild Steel
    Its often a hit and miss buying drill bits in bulk packages. I am often suspicious of these titanium coated chinese made drills. But you are getting real nice swarf. I drill a bit slower than that but its hard to tell on a video. But you seem to have done it effortlessly.What are you making.?
    You are lucky you know how to sharpen a drill. Many people just go buy a new one.
    Apr 2018
    Fraserburg
    Thanked: 910
    The swarf shows that your drill bit is sharp and the pressure on the bit is correct. The speed seems to be a bit more than I would use but it may be the effect of the video.
    Gaborone, Botswana
    Thanked: 1195
    Swarf. Always wanted to know the correct word for those curly thingies that comes out.
    Kobus
    Gaborone, Botswana
    Thanked: 1195
    I will post pics when I'm done
    The small bits I buy new. The bigger ones I sharpen on a hit and miss base. Mostly I get it right the first time. Sometimes I need to give it a second try on the grinder. I have up to 24mm bits . A bit expensive to go buy new every time they go blunt.
    Kobus
    durban
    Thanked: 1112
    Anything under 5mm I chuck.The beauty with knowing how to sharpen a drill is that you can fine tune it. Different way to sharpen a drill for steel to brass to plastic etc. If you want to drill through sheet metal ,a very different way to sharpen it.
    Sep 2011
    Potch/Brits
    Thanked: 583
    Its time you started a video tutorial on drill sharpening
  9. The Following User Says Thank You to carlp For This Useful Post:
    Mar 2017
    Okahandja
    Thanked: 726
    Yes that will be good.
    Thanked: 199
    I trust Ruwag for a decent drillbit!
    If you want to see a quick drill, buy their Turbo Metal bits, sizes bigger than 5mm has its own pilot bit.
    Si vis pacem, para bellum
    Apr 2018
    Fraserburg
    Thanked: 910
    We used to use these for fast drilling in in plate metals.
  13. #11
    durban
    Thanked: 1112
    Ive never tried one but seen them on you tube and they look very useful.
  14. #12
    durban
    Thanked: 1112
    Quote Originally Posted by carlp View Post
    I battle sending an e mail. You tube ,no chance .
  15. #13
    Thanked: 14159
    I need a drill press. And a vice. And a proper bench.
    You don't realise how useful this stuff is until you don't have them.
  16. #14
    Thanked: 446
    You always see these on Youtube. Thought about getting one the other day but the price made me walk away...fast.
    2004 Defender 110 Td5
  17. #15
    Jan 2015
    Vredenburg
    Thanked: 943
    Quote Originally Posted by Sawdust View Post
    You can by them through Wish for a tenth of the price. But it seems the "going postal office" is coluding in boycoting any and all imports. All my orders have never arrived.
  18. #16
    Thanked: 675
    Quote Originally Posted by Karoo Klong View Post
    I got 5 out of 6 orders, - but took ages. The most expensive item never arrived, - presume stolen by SAPO. Wish refunded me though, - no problems.
    2010 Bombardier Electrostar 746 kw - Gautrain (Daily Commute)
  19. The Following User Says Thank You to Kortgat For This Useful Post:
  20. #17
    Gaborone, Botswana
    Thanked: 1195
    Playground Swing Hangers
    This is the problem.
    The commercial solution. It will be a bit over the top for 5 sets.
    My solution. Ugly but functional.
    All 5 sets
ID:	504106   Click image for larger version.
ID:	504107   Click image for larger version.
ID:	504108   Click image for larger version.
ID:	504109   Click image for larger version.
    Kobus
