Ga-Ma "trail" on Klein Pella, Northern Cape for the adventurous - Page 9
Page 9 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 161 to 180 of 257
  1. #161
    Robertson/ Larissa, Greece
    Thanked: 2556
    Default Re: Ga-Ma "trail" on Klein Pella, Northern Cape for the adventurous
    Sheesh, that's hard work!
  2. #162
    Jan 2014
    Thanked: 472
    Ek dink jy het nou genoeg gewys hoe jy die Trail bou. As jy ons nou 'n klomp geld vra om die trail te ry gaan dit net al hoe moeiliker raak om te sÍ jy vra te veel
  3. #163
    Kathu
    Thanked: 2379
    Hierdie trail is op by bucket list. Nog net hoe waar en wanneer. My jaar is nogal vol beplan wat 4x4 aktiwiteite aan betref.
  4. The Following User Says Thank You to grips For This Useful Post:
  5. #164
    Sep 2018
    Not too far from Pofadder
    Thanked: 328
    I have been a bit busy the past week, and the one time that I did manage to get out to the trail I wanted to clear out the top of the pass. The reason I decided on this particular route down from the mountain is because of this natural gulley that runs down most of the way.
    I only have to clear away a few rocks and managed about 50m in about 30 minutes with a bit of help.
    About halfway down there is a couple of narrows, but clearing this out is quick. and will leave a few interesting obstacles.
    The gulley runs for about 150m and would have cleared easily earlier, but i had to make sure I could actually make it down the bad stretch before I did the easy bit.
  6. The Following User Says Thank You to Bex For This Useful Post:
  7. #165
    Dec 2010
    Lichtenburg
    Thanked: 34
    I absolutely LOVE the fact that you go up and down your trail like a Klipspringer with a 20+ year old designed NP300 trying to make it rideable for current state of the art 4x4's
    Si vis pacem, para bellum
  8. #166
    Sep 2018
    Thanked: 328
    Secretly I enjoy the fact, but I try not to emphasize it when others do the trail as it seem to dampen their spirits and like them to remember the trip as them conquering the trail.
  9. #167
    Sep 2018
    Thanked: 328
    I am looking forward to Saterday , I have some scouts coming to check out the trails for an event that they will be holding in a couple of months in which a large number of vehicles will paticipate. I will take some pictures over the weekend.
  10. #168
    Sep 2018
    Thanked: 328
    Not much time available, so I dashed in tonight to clear another easy bit at the top of the pass.
    First a bit of a drop with some rocks to break up and fill in.
    and then an easy stretch with just a couple of loose rocks to chuck aside.
    I have about 15m to go to the top of the pass, I hope to have some time to get it there on Sunday.
  11. #169
    Sep 2018
    Thanked: 328
    I had 2 vehicles on the trail today, an older and a newer Hilux. There is just no comparison between the 2 , the newer D4D was dificult to thread through, the low slung nudge bar did a lot of nudging. The older raider just skipped through like it was nothing. the older pickups were just beter.
    Edging past "Gert se klip". it is not just narrow, but a steep descent with not much chance to go back up if your line isnt right. to make it worse the right wheel drops down at the end making the vehicle lean into the rock.
    The shelf at the start of the B route is surprisingly dificult for the new vehicles while for the older ones it is a a straight drive down.
    It did make it over without bending something
    Mark's boulder was a hit, a steep climb onto a boulder with a tight turn at the start.
    And important to note , the Raider was the first vehicle down the shute to the unfinished pass, here coming back up out of it.
  12. #170
    Thanked: 17
    Hey Bex. Great to see the trail being used. Time for a return trip!
  13. #171
    Sep 2018
    Thanked: 328
    Quote Originally Posted by milbury View Post
    Route C is almost ready, that should make the trip worthwhile.
    I finally managed to get the digger out here to do the bottom part of the pass.
    There was a lot of large boulders to roll out of the way.
    The slope is really steep and the machine will tip over backwards if I try to go up forwards, so I reverse up and rake the rocks down bit by bit. There is the danger of a big one rolling down into the machine, so I would first pul down a bunch of smaller ones and make a wall for the bigger ones to stop against.
    Unfortunately I was concentrating too much while working to take pictures. In this picture you can make out the top of the pass in top centre of the picture.
    The path goes up the middle first, then to the right behind the tree, the it goes up a bit, and cross all the way to the left.
    I took the machine up as far as it would go, the rest I need to do by hand.
  14. #172
    Thanked: 17
    Brilliant. Beats a crowbar and a hammer!!
  15. #173
    Sep 2018
    Thanked: 328
    True, it does make the job much easier, the problem is that the digger is very top heavy and could only get halfway up going forward before there was no weight on the front wheels to steer with, and I had to position the back hoe so it would press on the ground if the front started to lift.
    Reversing got me up a lot further and that is how I worked. The total that the machine managed to do was 23 m on a 2.1km piece of track, barely over 1%.
    The machine could do all of it, but that would mean making slopes that the machine can manage which would be a normal road.
  16. #174
    Sep 2018
    Thanked: 328
    I took Klipspringer (he has been called that by too many now to think of another name) up to where I got with the machine to give some perspective.
    And though it was starting to get risky with the top heavy machine it is not much for a 4x4.
    Lots of rocks had to be moved carefully to clear this out. What made this area particularly dificult to do by hand was because it was loose boulders sitting on sand, there was no convenient support points for levers to push against.
    There are less boulders as you go further up, so that can be done by hand again.
    I finally cleared the approach to the pass from the top tonight, so it is possibly now to drive right up to it.
    Only a small unpassable section still remains, the path goes down to the right, and then crosses over completely to the left before going down to where the Hardbody is peeking through the bushes.
  17. The Following User Says Thank You to Bex For This Useful Post:
  18. #175
    Sep 2018
    Thanked: 328
    Another 4m of progress made.
    Up above where I am it is leveling out slightly , and at teh back you can see where it meets up with the finished part.
    The work area seen from the top.
    While I was up there I took a picture of the top part of the pass. The path runs up that gully to the left of centre in the pic.
  19. The Following User Says Thank You to Bex For This Useful Post:
  20. #176
    Sep 2018
    Thanked: 328
    I went for a quick stress relieving session.
    Exactly 1 hour and about 4m of progress. I think the remaining bit is under 20m now.
    The first drive through is sure going to be sweet , I can almost taste it already.
  21. #177
    Sep 2018
    Thanked: 328
    Moving big rocks is easier if you balance them.
    Place rocks just off centre and rock them from one balance point to the next until it has moved enough.
    About 4m done again and about 15m remaining.
  22. The Following User Says Thank You to Bex For This Useful Post:
  23. #178
    Sep 2018
    Thanked: 328
    I left the site yesterday thinking about thegap between these rocks. I measured it and the Hardbody will get through it easy enough, but someone will scratch their newer wider vehicle eventualy. I was of 2 minds on whether to move the boulders on hte left slightly vs breaking down the one on the right that the crowbar is leaning against.
    I am leaning towards breaking up the one on the right as it will give me material to make a bit of a hump there that will help keep running water off the path.
  24. The Following User Says Thank You to Bex For This Useful Post:
  25. #179
    Sep 2018
    Thanked: 328
    In case anyone was thinking I am making it too easy, I can tell you that I wished I had a crawler gear going up to where I had the trail finished to. The hardbody was struggling in 1st gear low range.
    As there was no space to turn I had to reverse down and because it is so steep and your wheels are slipping at times you end up in a line that will not work, so you have to go up again and choose a line down that will cause you to slip into the correct line.
    I took the hardbody up there to see if I am making the path wide enough, and it was a good thing, as it is not.
    The rock was just too solid for the hammer to do anything to it, so I used the chisels.
    There was some really uncomfortable angles to swing the sledge at.
    The rock looks all cracked up and porous on the outside, but as you go deeper it is just solid.
    I managed to knock a bunch of pieces off it before I started overheating and had to leave it.
  26. The Following User Says Thank You to Bex For This Useful Post:
  27. #180
    White River
    Thanked: 861
    Amazing work Bex. Please take a video of your first ride through the pass.
    2011 JK Wrangler Rubicon 3.8
